Home > Maintenance & Modifications > Defender 90 heated seat upgrade |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
I believe Brit Part supply a kit which includes heat pads looms and switches etc. to fit to your current seats. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
13th Sep 2022 7:28am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
I fitted the Waaco one about 6years ago and it has worked nicely. I only wired the higher power setting in so I could use the genuine dash switches.
I suspect the Britpart one may well be the same kit re-branded. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
13th Sep 2022 8:03am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2108 |
I understand that Exmoor Trim and MobileCentre may be able to help.
13th Sep 2022 11:07am |
