Home > Puma (Tdci) > VCV Fuel Valve Denso
llessur
Can anyone help with the Denso part numbers for the Denso Fuel Control Valve on a 2.4 TDCi
The one I took off is a Denso 294009-0360
The one I just bought listed for the 2.4 TDCi is 249009-0160
The one on the wifes 2.4TDCi is 294009-0260
I have no idea if the valve got superceded with revised numbers or if the are differences to the valve or which one I should be using. The 0360 and 0260 version have worked up to now.
Does anyone know the difference please
Post #931016 24th Nov 2021 6:13pm
AndyS
I can't find the page where I read it so this could be wrong but I think the second part of the number is a batch number so can be ignored.
Post #931063 25th Nov 2021 2:23am
dorsetsmith
Genuine Denso Control Valve 294009-0260 used in
Make Model Size bhp Years Engine Code and Other Specifications
Citroen Relay 2.2 d 100-120 2006- 4HU, P22DTE, HDI, 100, 120
Fiat Ducato 2.2 d 100 2006- 4HV, D, Multijet, 100
Ford Ranger 3.2 d 197 2011- PUMA, SAFA, TDCi, 4x4, I5
Ford Transit 3.2 d 197 2008-2014 PUMA, SAFA, SAFB, TDCi, I5, 4x4
Ford Transit 2.4 d 100-140 2006-2007 PUMA, H9FB, H9FD, TDCi, Tourneo
Ford Transit 2.2 d 84-110 2006-2014 P8FA, P8FB, QVFA, PUMA, TDCi, Tourneo
Isuzu D-Max 3.0 d 2007- 4JJ1, 4JJ1-TC, 4JJ1-TCX, Rodeo, Holden, Colorado
Isuzu D-Max 2.5 d 136 2007- 4JK1-TC, Rodeo, Holden, Colorado
Isuzu F Series 5.2 d 148-175 2004- 4HK1, 4HK1-TCC, 4HK1-TCS, FRR, FSR, FTR, FVR, FSS
Isuzu N Series 5.2 d 148-175 2004- 4HK1, 4HK1-TCC, 4HK1-TCS, NPR, NQR, NRR
Land Rover Defender 2.4 d 122 2006- PUMA, ZSD-424, TD4, 4x4
Mazda 3 2.2 d 125-185 2008- R2, R2AA, 200MPa, MZR-CD, MZRCD
Mazda 3 2.0 d 143 2006-2009 RF7J, MZR-CD, MZRCD, MZR, BK
Mazda 5 2.0 d 110-143 2005- RF7J, MZR-CD, MZRCD, MZR, CR19, CD
Mazda 6 2.2 d 125-185 2008- R2, R2AA, 200MPa, MZR-CD, MZRCD
Mazda 6 2.0 d 140 2005- RF7J, MZR-CD, MZRCD, MZR, GH
Mazda 6 2.0 d 121-136 2002-2007 RF5C, Di, GG, GY, SW, CiTD
Mazda CX-7 2.2 d 125-185 2008- R2, R2AA, CX7, 200MPa, MZR-CD, MZRCD
Mazda MPV 2.0 d 136 2002-2006 RF5C, Di, II, 2, LW
Mitsubishi L200 3.2 d 160-165 2006- 4M41, Di-D, KA_T, KB_T, HP, 4WD
Mitsubishi L200 2.5 d 136-178 2009- 4D56 HP, Di-D, KA_T, KB_T, HP, 4WD
Mitsubishi Pajero 3.2 d 160-190 2007- 4M41, Di-D, Montero, V8_W, V9_W, V90, V80
Mitsubishi Pajero 2.5 d 136-178 2009- 4D56 HP, Di-D, Sport, Montero
Nissan Almera 2.2 d 136 2003- YD22DDTi, YD22ETI, dCi, II, 2, N16, Tino, V10
Nissan Navara 2.5 d 130-175 2005-2006 YD25, DDTi, Di, D22, Euro 3, D40, dCi, NP300
Nissan Pathfinder 2.5 d 163-175 2005-2006 YD25, DDTi, dCi, R51, 4WD, Euro 3, D3
Nissan Primera 2.2 d 126-139 2003- YD22DDT, YD22ETI, dCi, P12, WP12
Nissan X-Trail 2.2 d 114-136 2003- YD22DDTi, YD22ETI, dCi, T30, 4x4, Euro 3, Euro 4
Opel Astra 1.7 d 108-125 2007-2010 A17DTJ, A17DTR, Z17DTJ, Z17DTR, CDTi, GTC
Opel Corsa 1.7 d 125 2006-2014 Z17DTR, CDTi, D
Opel Meriva 1.7 d 99-125 2003-2010 A17DTR, Z17DTR, CDTi, A, B
Opel Zafira 1.7 d 108-125 2008-2014 A17DTJ, A17DTR, Z17DTJ, Z17DTR, CDTi, B
Peugeot Boxer 2.2 d 100-120 2006- 4HU, P22DTE, HDI, 100, 120
Vauxhall Astra 1.7 d 108-125 2007-2010 A17DTJ, A17DTR, Z17DTJ, Z17DTR, CDTi, GTC
Vauxhall Corsa 1.7 d 125 2006-2014 Z17DTR, CDTi, D
Vauxhall Meriva 1.7 d 99-125 2003-2010 A17DTR, Z17DTR, CDTi, A, B
Vauxhall Zafira 1.7 d 108-125 2008-2014 A17DTJ, A17DTR, Z17DTJ, Z17DTR, CDTi, B
And compatible with the Following Part Numbers
Manufacturer Original Equipment
294009-0120
294009-0260
Post #931069 25th Nov 2021 7:42am
When I got mine from PF Jones, it was a Genuine Nissan part.
Works perfectly. Thumbs Up $W33T $0U7H3RN $UG4R
Post #931102 25th Nov 2021 1:03pm
llessur
This would make sense as clearly different sellers supply VCV's with different part numbers.
When I have had these fail I have always replaced with Genuine Denso units. I just could not understand why I was receiving VCV's with different part numbers each time and if it was a case that the units had been revised by Denso because they were aware of the failures, I was using the latest revision.
Quite surprised with the list of vehicles these fit though. I wonder if they experience the failure rate that Defender owners do.
Thanks everyone
Post #931122 25th Nov 2021 3:39pm
bear100
Having some issues on my back from LRO Petebog I'm pretty sure my VCV is giving up the ghost with the usual symptoms, i have changed it a few years ago but forgot the part number, just looking at this thread with the part number suggested, all the results come back with a Suction Control Valve, is this the same as a Vapour Control Valve? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #964655 11th Sep 2022 4:21pm
llessur
Yes, the Land Rover VCV is the Denso Suction Control Valve. Same thing
Post #964657 11th Sep 2022 4:27pm
jst
Thanks everyone
L200s definitely have same problems with them. Just changed one Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #964668 11th Sep 2022 6:59pm
bear100
Thanks for the info, SCV & VCV the same Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
Post #964674 11th Sep 2022 8:06pm
bear100
I’m finding that they range from £28 to £100 for the same valve all have the same part number all say new and Denso 2016 Range Rover Autobiography 4.4 TDV8
Post #964675 11th Sep 2022 8:09pm
