Home > Puma (Tdci) > VCV Fuel Valve Denso |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
I can't find the page where I read it so this could be wrong but I think the second part of the number is a batch number so can be ignored.
25th Nov 2021 2:23am |
Genuine Denso Control Valve 294009-0260 used in
Make Model Size bhp Years Engine Code and Other Specifications Citroen Relay 2.2 d 100-120 2006- 4HU, P22DTE, HDI, 100, 120 Fiat Ducato 2.2 d 100 2006- 4HV, D, Multijet, 100 Ford Ranger 3.2 d 197 2011- PUMA, SAFA, TDCi, 4x4, I5 Ford Transit 3.2 d 197 2008-2014 PUMA, SAFA, SAFB, TDCi, I5, 4x4 Ford Transit 2.4 d 100-140 2006-2007 PUMA, H9FB, H9FD, TDCi, Tourneo Ford Transit 2.2 d 84-110 2006-2014 P8FA, P8FB, QVFA, PUMA, TDCi, Tourneo Isuzu D-Max 3.0 d 2007- 4JJ1, 4JJ1-TC, 4JJ1-TCX, Rodeo, Holden, Colorado Isuzu D-Max 2.5 d 136 2007- 4JK1-TC, Rodeo, Holden, Colorado Isuzu F Series 5.2 d 148-175 2004- 4HK1, 4HK1-TCC, 4HK1-TCS, FRR, FSR, FTR, FVR, FSS Isuzu N Series 5.2 d 148-175 2004- 4HK1, 4HK1-TCC, 4HK1-TCS, NPR, NQR, NRR Land Rover Defender 2.4 d 122 2006- PUMA, ZSD-424, TD4, 4x4 Mazda 3 2.2 d 125-185 2008- R2, R2AA, 200MPa, MZR-CD, MZRCD Mazda 3 2.0 d 143 2006-2009 RF7J, MZR-CD, MZRCD, MZR, BK Mazda 5 2.0 d 110-143 2005- RF7J, MZR-CD, MZRCD, MZR, CR19, CD Mazda 6 2.2 d 125-185 2008- R2, R2AA, 200MPa, MZR-CD, MZRCD Mazda 6 2.0 d 140 2005- RF7J, MZR-CD, MZRCD, MZR, GH Mazda 6 2.0 d 121-136 2002-2007 RF5C, Di, GG, GY, SW, CiTD Mazda CX-7 2.2 d 125-185 2008- R2, R2AA, CX7, 200MPa, MZR-CD, MZRCD Mazda MPV 2.0 d 136 2002-2006 RF5C, Di, II, 2, LW Mitsubishi L200 3.2 d 160-165 2006- 4M41, Di-D, KA_T, KB_T, HP, 4WD Mitsubishi L200 2.5 d 136-178 2009- 4D56 HP, Di-D, KA_T, KB_T, HP, 4WD Mitsubishi Pajero 3.2 d 160-190 2007- 4M41, Di-D, Montero, V8_W, V9_W, V90, V80 Mitsubishi Pajero 2.5 d 136-178 2009- 4D56 HP, Di-D, Sport, Montero Nissan Almera 2.2 d 136 2003- YD22DDTi, YD22ETI, dCi, II, 2, N16, Tino, V10 Nissan Navara 2.5 d 130-175 2005-2006 YD25, DDTi, Di, D22, Euro 3, D40, dCi, NP300 Nissan Pathfinder 2.5 d 163-175 2005-2006 YD25, DDTi, dCi, R51, 4WD, Euro 3, D3 Nissan Primera 2.2 d 126-139 2003- YD22DDT, YD22ETI, dCi, P12, WP12 Nissan X-Trail 2.2 d 114-136 2003- YD22DDTi, YD22ETI, dCi, T30, 4x4, Euro 3, Euro 4 Opel Astra 1.7 d 108-125 2007-2010 A17DTJ, A17DTR, Z17DTJ, Z17DTR, CDTi, GTC Opel Corsa 1.7 d 125 2006-2014 Z17DTR, CDTi, D Opel Meriva 1.7 d 99-125 2003-2010 A17DTR, Z17DTR, CDTi, A, B Opel Zafira 1.7 d 108-125 2008-2014 A17DTJ, A17DTR, Z17DTJ, Z17DTR, CDTi, B Peugeot Boxer 2.2 d 100-120 2006- 4HU, P22DTE, HDI, 100, 120 Vauxhall Astra 1.7 d 108-125 2007-2010 A17DTJ, A17DTR, Z17DTJ, Z17DTR, CDTi, GTC Vauxhall Corsa 1.7 d 125 2006-2014 Z17DTR, CDTi, D Vauxhall Meriva 1.7 d 99-125 2003-2010 A17DTR, Z17DTR, CDTi, A, B Vauxhall Zafira 1.7 d 108-125 2008-2014 A17DTJ, A17DTR, Z17DTJ, Z17DTR, CDTi, B And compatible with the Following Part Numbers Manufacturer Original Equipment 294009-0120 294009-0260 |
25th Nov 2021 7:42am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20474 |
When I got mine from PF Jones, it was a Genuine Nissan part.
Works perfectly. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
25th Nov 2021 1:03pm |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 |
This would make sense as clearly different sellers supply VCV's with different part numbers. When I have had these fail I have always replaced with Genuine Denso units. I just could not understand why I was receiving VCV's with different part numbers each time and if it was a case that the units had been revised by Denso because they were aware of the failures, I was using the latest revision. Quite surprised with the list of vehicles these fit though. I wonder if they experience the failure rate that Defender owners do. Thanks everyone |
25th Nov 2021 3:39pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1921 |
Having some issues on my back from LRO Petebog I'm pretty sure my VCV is giving up the ghost with the usual symptoms, i have changed it a few years ago but forgot the part number, just looking at this thread with the part number suggested, all the results come back with a Suction Control Valve, is this the same as a Vapour Control Valve? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) Last edited by bear100 on 11th Sep 2022 4:39pm. Edited 1 time in total |
11th Sep 2022 4:21pm |
Yes, the Land Rover VCV is the Denso Suction Control Valve. Same thing
11th Sep 2022 4:27pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8086 |
L200s definitely have same problems with them. Just changed one Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
11th Sep 2022 6:59pm |
Thanks for the info, SCV & VCV the same 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
11th Sep 2022 8:06pm |
I’m finding that they range from £28 to £100 for the same valve all have the same part number all say new and Denso 2016 Range Rover Autobiography 4.4 TDV8
11th Sep 2022 8:09pm |
