Home > Technical > LED headlight globes
Page 1 of 3 123>
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
I've ordered a new pair of high crystal headlights for my Defender but don't know if I should stick with halogen globes or go LED, what are peoples thoughts?, thanks
Post #964472 9th Sep 2022 12:06pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
LED 'H4' replacement units are illegal and will fail an MOT. Invest in some decent H4 halogen bulbs and upgrade the headlamp wiring harness (a couple of options available commercially) so the bulbs get full battery voltage and the lights will be great.
Just one example of a headlamp wiring loom upgrade here -
https://www.paddockspares.com/boomslang-pe...-loom.html
Not the one I've got so can't comment on it either way, but you get the idea.
100watt H4 bulbs would most likely melt the lens of the Crystal lights as they generate a tremendous amount of heat. Polycarbonate is tough but it will melt.
Post #964476 9th Sep 2022 12:19pm
Decent LED bulbs such as those supplied by Classic Car LED's are excellent but as Penfold says, are now illegal in the UK. You'd have to check your local rules before committing to them. Darren
Post #964480 9th Sep 2022 12:45pm
Penfold_6290
Didn't spot the OP was from Australia ref MOT issues.
Post #964481 9th Sep 2022 12:50pm
camelman
And only illegal in post 1986 vehicles in the UK 😉
Post #964482 9th Sep 2022 1:04pm
Having run with LED conversion "bulbs" in Wipac crystals for a time, I can assure the OP that they produce a cleaner, brighter, more sharply defined, and generally superior light pattern than any halogen bulb. They will also, with no problem, pass a UK MOT test beam alignment check and will not cause inconvenience to other road users (which is more than can be said for modern adaptive beam and matrix lamps, which presumably but inexplicably are legal).
In the UK the illegality is purely due to to type approval reasons and not due to function (and is arguably and affront to common sense), but the sad fact remains that they are technically illegal on post-'86 vehicles.
I replaced my "crystal plus LED bulb" with top-quality, type approved LED units, which produce a significantly inferior main beam but are broadly comparable on dip.
If it is legal for you to go LED, or if you are prepared to take the risk if it isn't, then go (quality) LED. The light output is better is every respect.
Post #964486 9th Sep 2022 1:33pm
+1 ^^^
I have the classic car type LED bulbs in my 110, and as BW says, the beam is soooo much crisper and sharper. It's also passed an MoT with no advisories regarding brightness/aim etc.
I know that "just because it passed an MoT doesn't make it legal", or "because a copper didn't pull me over blah blah", but wanted to pass my 2p's worth on.
Post #964489 9th Sep 2022 2:29pm
MK
DO those "Classic Car LED's " get too hot for the rubber cap? Puma 110" SW
Post #964491 9th Sep 2022 2:54pm
On the contrary.... they run very cool.
Post #964492 9th Sep 2022 3:00pm
kenzle8a
What ones did you fit? I went back to Crystals and miss my Tuck Lites but couldn't bear the though of smashing a £600+ set of head lights on the farm. The horse had nearly nutted one of the Truck Lites in the yard...
Post #964493 9th Sep 2022 3:05pm
MK
Funny thing those bulbs do not fit into my crystal headlights (LHD) . Bulb´s diameter is a bit bigger than the hole on the lens Puma 110" SW
Post #964494 9th Sep 2022 3:06pm
When was your last MOT, Jim? They shouldn't fail because of anything to do with the beam pattern but just because they've been deemed illegal. If the test was recent then you tester has either just missed them or isn't aware of the changes. Darren
Post #964495 9th Sep 2022 3:19pm
You must have used a different make, MK, because lots of us have fitted the Classic Car LED's version to our crystal headlights. Darren
Post #964496 9th Sep 2022 3:21pm
MK
Bought them from the same company. Shocked Puma 110" SW
Post #964497 9th Sep 2022 3:24pm
Dunno what to say then - something is clearly different Confused
 Darren
Post #964498 9th Sep 2022 3:36pm
Page 1 of 3 123>
