Home > Technical > LED headlight globes
Page 2 of 3 <123>
lord-haggis wrote:
blackwolf wrote:
I replaced my "crystal plus LED bulb" with top-quality, type approved LED units, which produce a significantly inferior main beam but are broadly comparable on dip.
What ones did you fit? I went back to Crystals and miss my Tuck Lites but couldn't bear the though of smashing a £600+ set of head lights on the farm. The horse had nearly nutted one of the Truck Lites in the yard...
As I recall they are JW Speaker, but the slightly earlier type (they were pre-owned when I bought them).
Don't get me wrong, they are much better than the original factory-fitted H4 lights, but not as awesome as the crystals with LEDs.
LandRoverAnorak wrote:
diesel_jim wrote:
It's also passed an MoT with no advisories regarding brightness/aim etc.
When was your last MOT, Jim? They shouldn't fail because of anything to do with the beam pattern but just because they've been deemed illegal. If the test was recent then you tester has either just missed them or isn't aware of the changes.
Ironically I took my crytals/LEDs out and fitted the integrated LED units last year (or maybe the year before now, I forget) because I assumed that my MoT tester would fail them, as he is now required to do. In conversation with him I mentioned what I had done, and he had no idea that he was meant to check for non-TA LED bulb conversions and as a result there would have been no problems whatsoever with the LED bulb set-up! Now of course he knows. Doh! Rolling with laughter
Post #964499 9th Sep 2022 3:44pm
MK
 Puma 110" SW
Post #964501 9th Sep 2022 3:56pm
Mo Murphy
That doesn't look like a classic car LEDs Headlamp bulb !
50 Shades of Pennine Grey
Post #964502 9th Sep 2022 4:02pm
MK
 Puma 110" SW
Post #964503 9th Sep 2022 4:06pm
Indeed not, this is what they should look like:
The substantial heatsink screws onto the back of the bulb once the bulb is in place. The connector is on a flying lead.
Edit: the second photo (which crossed this post) just deepens the mystery, especially as the bulb pictured doesn't match the one in the photo on the box.
Post #964504 9th Sep 2022 4:09pm
MK
Actually I bought them from the UK based seller. Are thoe ones you show fan cooled? Puma 110" SW
Post #964505 9th Sep 2022 4:10pm
Oh dear! Perhaps they have undergone a "value engineering" process. That doesn't bode well.
Update: after checking the Classic Car LEDs website they appear to be the £48 "poverty spec" bulbs, not the £65 premium version.
Poverty spec: https://www.classiccarleds.co.uk/products/...rade-bulbs
Premium: https://www.classiccarleds.co.uk/products/...sion-9-32v
Be that as it may, if they don't fit the headlight I think I would be having a conversation with the supplier. I appreciate that geography is not in your favour though.
Post #964506 9th Sep 2022 4:12pm
MK
Sad Puma 110" SW
Post #964509 9th Sep 2022 4:19pm
landy andy
Classic car led’s in mine. MOT all ok. Thumbs Up
Post #964521 9th Sep 2022 5:57pm
markb110
Tempted to put mine back in now the nights are drawing in…. Whistle
Post #964523 9th Sep 2022 6:45pm
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
Okay looks like I'll be fitting the classic car LED globes, many people over here run 7'' LED's, I've found mine to be worse than the original high crystal Osram night eater halogens so I'm going back, I live and work remote so need good lights, I've ordered brand new HC lights from Paddocks and will order the Classic LED globes and give them a go.
Post #964535 9th Sep 2022 10:39pm
PAT303
All ordered, I already have an updated wiring loom, new high crystal bowls with classic car LED globes, sorted, thanks everyone.
Post #964536 9th Sep 2022 10:44pm
PAT303
Just some feedback, fitted a locally supplied loom, brand new high crystal bowls with classic car LED's and the results are spectacular, I've owned my Tdi for 24 years and she finally has the best lights, not just the best but THE BEST headlights she's ever had, I don't see any reason for anything else, you want good lights do what I did, you'll never regret it.
Post #966239 29th Sep 2022 10:05am
Glad your happy with them! I agree that it is the best lighting combination, it is just infuriating that here in the good old ECE some half-witted bureaucrat who probably wouldn't know his you-know-what from his elbow has decided that using this combination is a mortal sin, even though it passes the mandatory annual beam alignment test.
Thank goodness we live in a free country!
Post #966247 29th Sep 2022 12:25pm
Sorry LRA, I missed this one.
MoT was last December. Will be interesting if it fails in a couple of months time Confused
Post #966262 29th Sep 2022 5:29pm
Page 2 of 3 <123>
