Home > Technical > How do I test my A/C compressor? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
Only thing you can check is if the clutch is engaging or not.
You may also find its connection (close to the compressor) and check if you have power on the connector. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
5th Sep 2022 8:07am |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 316 |
With the engine off I'd be inclined to apply 12v directly to the compressor plug and listen to hear the clutch operating, it should make a clicking/clunking noise. Run a cable from the battery to do this, don't forget you'll need an earth too.
If the compressor engages then you need to eliminate a wiring/fuse issue in the vehicle itself. Most systems will not engage the compressor if the gas pressure is too low. So if you have not used the system for a long time the seals may have deteriorated and you have lost your gas. With the engine running you could force the compressor to engage and see if the pipes get cold, but I wouldn't recommend it. You can buy cans of refrigerant gas from auto stores but if you've lost gas pressure that means an issue somewhere in the system so you probably ought to seek the help of an aircon expert who can detect a leak for you. |
5th Sep 2022 9:52am |
It could be a fuse or a relay. But, it is worth knowing that the compressor will not work if the system is not charged with refrigerant to the correct pressure. It is incredibly common for the condenser to spring a leak and release the refrigerant, then the compressor will not function even if supplied with 12v. |
5th Sep 2022 11:03am |
