Home > Technical > Poor running 1995 110 3.5 V8 after hot start - sometimes...?
nolift911
United States 1995 Defender 110 V8 Petrol CSW Alveston Red
Good afternoon mates -
Trying to diagnose a poor running condition on a 1995 3.5 V8 dual carbs. Issue comes and goes so it hard to diagnose. Generally shows itself after a hot restart. Smells like it is running rich or the choke is stuck. Pulled plugs after and they are dry so not sure exactly if it is a running rich issue or other. Seems to give black smoke and smells like fuel out the back though when it happens. Let it sit for 15-20 minutes all good, sometimes never comes back after driving but has been acting up lately. When it happens when I am driving it seems like it has gone into limp mode, no power, won't idle etc.
Any thoughts? carbs are topped up, checked the ignition components and they checked out ok.
Thanks -
Post #963389 30th Aug 2022 4:32pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Do you have phenolic spacers fitted between the carbs and the inlet manifold? If not, fuel evaporation could be a consideration.
Carbs are sensitive to temperature and will fuel differently when the engine is at operating temperature versus at cold. It’s possible that one or both of the carbs are over-fuelling the engine when at operating temp.
I would see if you can find someone in your area that is experienced in tuning cards and have them go over everything. You might find you are in need of carb rebuilds. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #963448 30th Aug 2022 10:04pm
The Zee
Was thinking the same, heat soak related fuel locking, the fuel vapourises in the lines/conections and then there are problems with running or starting.
Had a problem with a VW Polo that did this on hot days/long journeys, failed to re-start or ran really rough for a while, moving the fuel line and adding some insulation helped. Zaid-M
www.DefencePhotos.com
Post #963492 31st Aug 2022 11:03am
nolift911
Interesting - what do these spacers look like? As far as I know the truck is bone stock....
Post #963505 31st Aug 2022 12:35pm
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
They are dark in colour like ebony and have an arrow moulded to show the correct orientation (airflow).
Item 63 on this page:
https://www.ukmgparts.com/catalogue/mgb-mi...t-manifold
Note that the ethanol content will make modern petrol more prone to evaporation and vapour lock.[/url]
Post #963507 31st Aug 2022 12:47pm
nolift911
Ah ok thanks - yes those are there at least. I tried adding a fuel stabilizer for ethanol content, we are at 10% give or take but did not seem to effect it much after a few tanks with the additive. So when this happens it seems like it is rich, not a fuel starvation problem, rather over fueling. When I pull the plugs right after they are dry though. The black smoke seems to me to be over fueling.
I was thinking then back to ignition p bad coil maybe that gets hot? Resistance in it shows 1 which is within range.
Jeff
Post #963508 31st Aug 2022 12:52pm
Rabbitwabbit
United Kingdom 1997 Defender 110 300 Tdi CSW Stornoway Grey
I run an old Range Rover classic on twin carbs and the new E10 fuel did have some impact. Sometimes I would find that fuel simply evaporated from the carbs when hot after a run - requiring a degreee of cranking before it would start - even when assisted by an electric fuel pump. I also found that the vehicle would stink of petrol fumes when in the garage after a run - this was down to the extra ethanol content escaping through the rubber pipes. The solution was to fit new E10 compatible plastic fuel pipes. This stopped the fumes in the garage and helped through less fuel evaporation. ----------------------------------------------
1997 Land Rover 110
1981 Range Rover Monteverdi Design Study
1974 Range Rover
1959 Series 2 (Now sold)
1971 Range Rover (Now sold)
1973 Lightweight (Now sold)
1981 Range Rover 4 door (Now sold)
1957 Series 1 LWB (Now sold)
1973 Range Rover (Now sold)
Post #963512 31st Aug 2022 1:28pm
nolift911
So you put an electric in line with the existing....?
Post #963513 31st Aug 2022 1:29pm
Rabbitwabbit
My Range Rover doesn't have the old mechanical lift pump - only an electric facet pump. When the ignition is switched on (before starting) I can hear the fuel prime through the system and you can see the fuel flowing from the tank, through the pump to the carbs, then returning via the return pipe to the tank. Therefore, when the carbs demand fuel there is a plentiful supply. ----------------------------------------------
1997 Land Rover 110
1974 Range Rover
Post #963515 31st Aug 2022 1:34pm
