Home > Maintenance & Modifications > How much rotation on axle before engaging with diff. F & |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5829 |
Been messing about with the Def, to tighten up backlash/clunk, including tightening a couple of loose bolts, replacing the rearmost UJ, which had seized/rusted/failed, checked seals on flanges, etc etc. Still yet to do a run. But whilst under I did a quick check of the front and rear axle rotation before being stopped by either front or rear diff, and I’m estimating that each turned approx 1cm before engagement. In the rear this was with the front of the prop off the handbrake drum, on the front both ends were fixed tight but the gearbox was in neutral.
Does 1cm sound about right? I checked fluids in each diff and they looked ok and at correct level (albeit the front diff was silvery grey and the rear diff a good quality gold, despite them both being changed at the same time), all bolts on the facing between prop and diff were tight, UJs all good (after replacement) etc. So what thoughts? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
30th Aug 2022 9:13am |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 359 |
Jip, sounds about right.
1/8th of a turn is normal. |
30th Aug 2022 9:42am |
Thanks JFH. I’d suggest it’s probably even less than that. Good to know. Taking her for a spin soon, to see what difference some tightening and a new UJ will have made Monsieur Le Grenadier
30th Aug 2022 9:49am |
I've found that greasing the prop shafts and UJs makes a difference but it only lasts for a short while.
30th Aug 2022 9:51am |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 833 |
1 piece rear shafts should also help. 2008 2.4 110 Utility Station Wagon XS.
30th Aug 2022 9:53am |
Definitely!
30th Aug 2022 9:55am |
Will buy them eventually, but at the moment both the shaft and flange are HD upgrades and there is no noticeable play. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
30th Aug 2022 10:08am |
