![]() | Home > Technical > Electrical issue related to brake circuit - 2014 tdci |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Hi .. did you ever solve this?
I’m having the same problem occasionally when braking at low rpm and the engine dies. It will start back up again no problem. |
Fmead99 Member Since: 02 Dec 2019 Location: Wiltshire Posts: 7 ![]() ![]() |
Hi,
I had various issues and fixed all of them. Not sure exactly which one solved it but in summary I changed the black brake sensor switch. And a problematic indicator stalk. But I think the main issue was a wobbly spade on the back of the ignition barrel switch. Good luck! |
