Home > Td5 > PAS pipes high pressure replacement
majorero
Hi!
I need to replace the high pressure PAS pipe. Does someone have an instruction at hand like the Haynes workshop manual? I ordered the Haynes manual yesterday, but the part comes today, and I would like to do the repair this weekend. Simon at https://www.youtube.com/c/LandRoverDrive shows the replacement for a LHD, but I have a RHD.
Help is greatly appreciated. Smile 1986 soft top, TD5
Northants response group
Post #962952 26th Aug 2022 9:51am
kenzle8a
This has got the steering box side of it on.
Post #962955 26th Aug 2022 10:38am
majorero
Thanks, but this is for the steering box. I would like to change the PAS pipe/line only. Do I have to remove the radiator for this? 1986 soft top, TD5
Post #962959 26th Aug 2022 11:54am
rallysteve
Shouldnt be any need to remove the radiator, you will be able to make some room by taking the viscous fan (note it is normal RH threaded unlike most viscous fans) and upper shroud off though.
I find a set of crows foot spanners makes doing the unions up on the box a bit easier but it is doable with normal spanners. Make sure you use the correct size spanner though to avoid rounding off the unions. Cant remember the sizes required but i think they are imperial.
High pressure pipe should be easy, union at each end and two small bolts on the back of the front crossmember which will release the pipe clamps.
If you have a syringe/fluid extractor then it will help to drain as much fluid from the reservoir as possible first as fluid will leak out of the ports once the pipe is removed.
As for bleeding it, slacken the bleed nipple on the top of the box and ensure no air is trapped in it. Then i usually just jack up the front wheels and turn from lock to lock a few times with the engine running and top up the fluid level.
You will obviously need some new PAS fluid.
Cheers,
Post #962960 26th Aug 2022 12:12pm
majorero
Thanks! Sounds doable. I hope the connection is correct. See photos.
 1986 soft top, TD5
Post #962968 26th Aug 2022 1:33pm
rallysteve
It does look a bit different but may well be correct. I suggest you remove just the union from the pump first to confirm your hose fits.
Cheers,
Post #962971 26th Aug 2022 2:21pm
majorero
I hope it's just a union and not welded on. Shocked
I'll give it a try this weekend. If not, I already have booked my local garage for Thursday. 1986 soft top, TD5
Post #962973 26th Aug 2022 2:35pm
htb2
Wales
the small nut is a ferrule on the pipe, the larger nut is an adaptor bolt that screws into the pump.
Just about to change the same pipe on mine, will let you know if there are any problems.
Post #962980 26th Aug 2022 3:16pm
majorero
Well, not so lucky I guess.
I thought that I was almost there, when I realized that one side had the wrong connection...
This is what I need:
And this is what I have:
The geometry of the pipe was good and the connector to my 4 bolt steering box was ok as well.
I'll talk to the shop tomorrow morning. 1986 soft top, TD5
Post #963211 28th Aug 2022 10:34pm
landy andy
I think you have the correct part. The two hex heads on your old pipe come apart. They are just rusted together. You can ruin the nut nearest to the rubber pipe if required, but must protect other as will need to be fitted again.
The two red marked hex heads are the same part I think, and the other part didn’t need to come out/off, but only did as they are rusted together.
Post #963213 29th Aug 2022 3:05am
majorero
Thanks! I see that at least the pipe is ok. So now I need the correct adapter. Any idea where I can get it from or what the name is?
 1986 soft top, TD5
Post #963220 29th Aug 2022 7:02am
htb2
Wales
I changed mine at the weekend with no problems.
Just a thought what P/S pump have you got fitted to yours as I am assuming its to go in a hybrid as you list your vehicles as a 1986 TD5. Did your engine come out of a discovery as the P/S pumps are slightly different on the HP outlet adaptor which you have shown, the Discovery one is smaller than a defender one. I am using a discovery pump but have used the defender outlet to mate to defender PS pipes.
Post #963221 29th Aug 2022 8:09am
majorero
I bought it this year, but the conversion was done by Devon 4x4 some years ago. I guess the TD5 came from a Discovery. I'll have a talk with them tomorrow. If I'm lucky, I can just find the ferrule adapter thingy. 1986 soft top, TD5
Post #963229 29th Aug 2022 9:16am
rustandoil
Can you not re-use the adapter?
Post #963234 29th Aug 2022 9:34am
majorero
The only one I have is on the picture, and it doesn't fit. Sad 1986 soft top, TD5
Post #963235 29th Aug 2022 9:35am
