Home > In Car Electronics > Flip image on optimill reverse cam and alpine head unit?
Co1
Hopefully this is the final question. Got the camera rigged up, but the image on the screen is mirrored, as in the image on the left of the screen is actually the view from the right of the car. There is no mention of this in the manual or online, any ideas how to flip it?
Post #962311 20th Aug 2022 10:41am
nitram17
never noticed ..i will have a look at mine .... im assuming if you rotate the camera ball 180'i the unit the picture is upside down/reversed?..just looked mine is the same ..i just use it for a quick look to make sure nobody is behind me (kids ect).....I would be interested to see if there is a fix?
Post #962317 20th Aug 2022 11:50am
Co1
I assume that will be the case, although I haven’t actually tested the theory yet!
Post #962318 20th Aug 2022 12:05pm
nitram17
how is yours wired?via reverse switch or permanent and switched off/on at the unit? Do you have the banner at the top saying look with your eyes?
edit i have found this https://manuals.plus/cs/jvc/kd-x561dbt-opt...z7cVRqlEcJ it may help as it talks about reversing image...I haven't got time this weekend to fiddle so i will be watching this thread with interest.
Post #962319 20th Aug 2022 12:09pm
Co1
Mine comes on with reverse. Just read in the MUD guide that you cut the two loops of wire hanging out of the camera flying lead. I’ll try that this afternoon and let you know.
Post #962322 20th Aug 2022 12:35pm
Co1
Can confirm, I cut the green loop only and it has flipped the image the correct way.
Post #962324 20th Aug 2022 12:56pm
nitram17
Thumbs Up ive got mine wired with the reverse .but im thinking of changing it to a direct ignition on feed as there are times when in traffic that it would be advantageous to have a view of the rear blind spots without the need to put it into reverse.
Post #962337 20th Aug 2022 4:16pm
nitram17
Which end is this green loop ?at the camera end or head unit end?
Post #962402 21st Aug 2022 2:23pm
Co1
It’s on the camera end.
Post #962403 21st Aug 2022 2:28pm
nitram17
Thumbs Up
Post #962405 21st Aug 2022 3:09pm
Ianh
Co1....showing my age here, but did it feel like you were in an episode of “Danger USB” as you hovered over the green wire with your side cutters just before you eventually cut it Very Happy
Post #962408 21st Aug 2022 3:39pm
bear100
Very Happy Thinking of one of these for my next purchase, any pics of the picture or your review on the quality of the picture etc 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #962440 21st Aug 2022 6:33pm
nitram17
That's a blast from the past Laughing Laughing danger UXB or can you remember doomwatch ..robert powel trying to defuse a bomb on the end of a pier..one way to end a series.
Post #962451 21st Aug 2022 8:37pm
nitram17
bear100 wrote:
Very Happy Thinking of one of these for my next purchase any pics of the picture or your review one the quality?
The picture is fine but be aware there is a huge blind spot in the image due to its off centre positioning ..it has a 170 degree camera arc.I have mine set so the transition of the yellow to the red tramline is one foot away from the nearside corner and one foot from the middle of the truck on the offside.
Post #962452 21st Aug 2022 8:44pm
nitram17
Re: Flip image on optimill reverse cam and alpine head unit?
hi col by right of by car do you mean drivers /offside?
im not sure whether I'm having a senior moment ..have you installed the optimil number plate camera unit or just the stand alone camera?the reason i ask is that i took a look tonight at my set up (NP unit)and there was no wire loop as described by mud to cut!
https://www.mudstuff.co.uk/collections/opt...rse-camera
i used the mud kit with the light piggy back. There is only one lead from the camera!so im a bit stumped as if you look on the mud website it gives you this picture as an example
unless that's a left hand drive that image is reversed isnt it?(spare wheel to right) or am i in need of a DAT scan.anyway that's how mine looks !any solutions?
Post #962453 21st Aug 2022 9:19pm
