![]() | Home > In Car Electronics > Flip image on optimill reverse cam and alpine head unit? |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3707 ![]() ![]() ![]() |
I left the white intact. Does it still work having cut both?!!
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
That's the problem it doesn't and i didn't check the camera before i cut it
![]() ![]() this will go down in my less rush pay more attention list of cockups! Last edited by nitram17 on 25th Aug 2022 6:26pm. Edited 1 time in total |
There isn’t a lot of slack on them either. Can you at least pare back the white one and solder it back together?
im going to try that tonight if i get time ..i did a quick burn of plastic and twist together earlier but that didn't work!
edit it didnt work ..so i think the camera is a dud! further edit.... after help from mr google......the green wire is for the image orientation and the white wire is for the tramlines....camera should work even if both are cut. |
