Home > Maintenance & Modifications > Vented discs - Drilled or not ? |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
That’s what i did, i got the whole lot from lof,
4th May 2022 4:49pm |
GM_FFX Member Since: 15 Sep 2021 Location: Washington DC Posts: 31 |
What brand do you guys prefer other than the OEM? It's for a ROW Defender 90. I don't plan to upgrade calipers or anything other than the rotors.
20th Aug 2022 5:48pm |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 289 |
What brand of rotors/discs do I prefer....
I've always had good customer service from EBC (https://ebcbrakes.com/) and have used them on my 3 prevoius vehicles. Luke at LOF (https://lofclutches.com/) has been very helpful and the current set of pads and rotors are fitted F&R. Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
20th Aug 2022 9:38pm |
As above EBC are superb for rotors. On my second set on Miffy, although EBC do not do (or did not do) a rear disc for a 110/130. So, I have Britpart drilled and grooved on the rear and they have also been superb
But... what made more of a difference to the breaking ability were the new brake servo, master cylinder and callipers... Night and day difference. Get those bits A1 at the same time as replacing the rotors and you will not go wrong. |
21st Aug 2022 10:03am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
going off at a very slight tangent I've found the biggest performance upgrade to be......
well lets put it like this I very nearly ploughed into a traffic island in my M3 a few years back which had all the 'fancy spec' on the brakes - none the less I still had to pay a visit to the laundrette. the defender has fairly low tech brakes by comparison but I've not even come close to having a similar issue......welll except for when I blow a seal on the front n/s caliper when going down a pass in the lake district. that aside. the best performance upgrade for the brakes is to drive slower had I not been doing 120mph approaching an island and leaving the braking a little late I'm sure the brakes would have pulled me up just fine. slow is good - everything becomes over engineered another for standard brakes (unless you're on the track with an ls3) |
21st Aug 2022 10:45am |
