![]() | Home > Td5 > Measurements for exchange.rear crossmember |
Defendertomten Member Since: 19 Aug 2020 Location: Avesta Posts: 48 ![]() ![]() ![]() |
Are there any specific measurements given when changing the rear crossmember?
Or is it just to center it and keep the old holes ss the old one🙄 Land Rover owner since 2003 2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
Ok thanks😁. I think i have to google some words😅. Perpendicular was new to me. Is aft a word or should it be after?
No, i have only cut it partly to see how bad it was. I have probably could have done a quickweld fix to mot it but i have own it for 18 years now and no plan to sell 😁. Land Rover owner since 2003 2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 ![]() ![]() ![]() |
aft - near, toward, or in the stern of a ship or the tail of an aircraft 1999 Defender TD5 110
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3472 ![]() ![]() ![]() |
Perpendicular is a 90 degrees between two lines, or in this case the tub support bracket and the rear face of the crossmember. If I remember correctly it was a perfect 90 degrees, checked by a large square. It was on a 90 though. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
So... i have forgotten the measures i made for the rear crossmember. Can anyone tell me or measure the distance from the tub support end to end of crossmember?
It seems like 2.5 inch would be likely to be right. But im asking anyway. Land Rover owner since 2003 2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
