Home > Td5 > Measurements for exchange.rear crossmember
Defendertomten
Sweden 2000 Defender 130 Td5 HCPU Coniston Green
Are there any specific measurements given when changing the rear crossmember?
Or is it just to center it and keep the old holes ss the old one🙄 Land Rover owner since 2003
2008 Disco3 manual
2000 Defender 130 td5 snorkel warn m6000
Post #962281 19th Aug 2022 6:56pm
Dinnu
Replaced once a basic crossmember, i.e. no extensions and before I cut off the old one, took measurements from the rear tub supports as I removed the tub to ease welding.
I took 3 main measurements:
1. How far aft it should be
2. How high it should be
3. How perpendicular it should be
Centering was the easy part, as the new crossmember had the openings for the chassis rails to fit.
Have you already cut off the old crossmember? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #962295 20th Aug 2022 4:34am
Defendertomten
Ok thanks😁. I think i have to google some words😅. Perpendicular was new to me. Is aft a word or should it be after?
No, i have only cut it partly to see how bad it was. I have probably could have done a quickweld fix to mot it but i have own it for 18 years now and no plan to sell 😁. Land Rover owner since 2003
2008 Disco3 manual
Post #962315 20th Aug 2022 11:38am
excossack
aft - near, toward, or in the stern of a ship or the tail of an aircraft 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #962339 20th Aug 2022 5:23pm
Dinnu
Perpendicular is a 90 degrees between two lines, or in this case the tub support bracket and the rear face of the crossmember. If I remember correctly it was a perfect 90 degrees, checked by a large square. It was on a 90 though. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #962361 20th Aug 2022 10:36pm
Defendertomten
So... i have forgotten the measures i made for the rear crossmember. Can anyone tell me or measure the distance from the tub support end to end of crossmember?
It seems like 2.5 inch would be likely to be right. But im asking anyway. Land Rover owner since 2003
2008 Disco3 manual
Post #1008004 17th Sep 2023 9:42pm
