Home > Puma (Tdci) > Wipers not working
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
Wipers not working
Hello my windscreen wipers and the rear window wipers are not working.
The washer is working, so looks like power must be getting so far.
I had checked the fuse but the washer I think confirms it’s ok.
There is a relay in the Haynes manual but no drawing for me to locate which relay it is.
Can anyone tell me what I should check next.
Post #961895 16th Aug 2022 4:57pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Useful link here:
https://www.lrworkshop.com/electrics/defen...nd-headers
Relay 3 under dash
Post #961912 16th Aug 2022 7:08pm
Crofter
Thanks that fills in a bit of the puzzle.
I had looked on the forum first, but this certainly makes it clear which relay works the wipers.
Post #961917 16th Aug 2022 8:03pm
Crofter
I found the fault in the front wipers one had sieized where the shaft to the wiper came through the body. Put Deblock on both got it working with a bit of help manually. Going great now.
Still to look at the rear wiper.
Post #962247 19th Aug 2022 3:18pm
Bear in mind if they seized and they are now free that it will come back and get worse, so before you get to that stage I’d recommend you get the parts to replace it before you need it and you maybe able to do it when convenient to you.
Otherwise they might let go in the middle of winter and be a real pain. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #962285 19th Aug 2022 8:30pm
Crofter
Good thinking that makes sense.
I will get them ordered.
Thanks
Post #962290 19th Aug 2022 8:57pm
Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #962292 19th Aug 2022 10:10pm
