![]() | Home > Puma (Tdci) > Wipers not working |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 341 ![]() ![]() ![]() |
Useful link here:
https://www.lrworkshop.com/electrics/defen...nd-headers Relay 3 under dash |
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 ![]() ![]() ![]() |
Thanks that fills in a bit of the puzzle.
I had looked on the forum first, but this certainly makes it clear which relay works the wipers. |
I found the fault in the front wipers one had sieized where the shaft to the wiper came through the body. Put Deblock on both got it working with a bit of help manually. Going great now.
Still to look at the rear wiper. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20759 ![]() ![]() |
Bear in mind if they seized and they are now free that it will come back and get worse, so before you get to that stage Iβd recommend you get the parts to replace it before you need it and you maybe able to do it when convenient to you.
Otherwise they might let go in the middle of winter and be a real pain. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Good thinking that makes sense.
I will get them ordered. Thanks |
![]() β½οΈπ’οΈβοΈπ§°πͺ |
