![]() | Home > Td5 > Bonnet release cable issue |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2698 ![]() ![]() |
There should be a lever that can be pulled to release the latch.
Visible on the latch here:
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Indeed it is possible but is a bit of a faff. From memory when i had to do this on mine (after reassembling the front end and realising i had forgotten to connect the cable just as i pushed the bonnet down to close it
![]() At least you dont have an A-bar, spotlights and winch as it makes getting the grille off so much more tricky! ![]() Steve 02' 110 TD5 Double Cab Rebuild Thread |
turnah Member Since: 30 Sep 2018 Location: Lancashire Posts: 40 ![]() ![]() ![]() |
Sorted, thank you very much everyone!
I managed to create a device out of a hacksaw to pull the lever. Quick wiggle of a wire and engine back in business too. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2948 ![]() ![]() |
Now fit a device to stop thieves opening your bonnet so easily !!
