Home > Maintenance & Modifications > Centre Exhaust replacement 2.2 |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2220 |
Go Straight through. Lose the weight and bulk. Any exhaust fabrication shop will easily put new piece of stainless and clamps on. Or of course there are numerous online offering this piece.
11th Aug 2022 12:16pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3432 |
I bought a straight through center section for my 90. Although I do not know the manufacturer, it was on the lower end of price.
Went to fit it last week, and the flanges and mount hangers were miles away. I tried to fit still, but then the rear exhaust was so crooked that it was pointing into the mudflap. To get a proper fit, I had to cut off both flanges, and re weld them, re position (just bending) the front hanger, and practically re manufacture the rear hanger. Here is a picture while work was in progress. I sacrificed my daughters kiddies chair back to use as a jig Click image to enlarge Bottom line, it was not worth the savings. And the flanges are mild steel not stainless. The tube is stainless though. Was not that I had purchased long time ago, I would have had returned it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
11th Aug 2022 12:52pm |
Ronniebee Member Since: 12 Oct 2015 Location: U.K. Posts: 31 |
Cheers, I think I’ll get someone to do it save me any grief.
11th Aug 2022 5:08pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2066 |
Demand engineering, straight through centre section all stainless steel, £192 , best fitment and quality.
https://shop.demandengineering.co.uk/produ.../#downpipe Search on here for demand and you will see glowing reports |
11th Aug 2022 5:33pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3685 |
In for a penny, in for a pound: do the lot! I went straight though from cat back. It’s no louder, all the muffling is done in the DPF, it breathes noticeably better, revs more freely and sounds better.
11th Aug 2022 6:19pm |
^ Co1
Your absolutely right. Did this when I got my 2.2 in 2012. Sounds great when it does a re-gen👍 |
11th Aug 2022 7:49pm |
Ha! Your right Keith. Every time it does a regen I crap myself for a split second until I realise what’s going on!
11th Aug 2022 7:50pm |
£200 the only thing that’s glowing at that price for a piece of stainless pipe should be embarrassment. |
11th Aug 2022 7:54pm |
Their prices have gone up....but then everything has gone up unfortunately.
11th Aug 2022 8:17pm |
Thanks, I’ve got no issues paying more for quality, I’ll look up Demand. Probably end up with the rear section as well. |
11th Aug 2022 8:53pm |
I got mine from Twisted. Great quality, probably a touch cheaper than Demand but not by much. Where abouts are you based?
12th Aug 2022 5:58am |
Dropped in this morning at a local garage. My pal had a look in the pit and suggested doing both sections middle and back and don’t go cheap or you’ll be doing them again in a couple of years time. I was a bit concerned as I pull a caravan and the next trip is in early September but he reckons the small split I filled with JB weld was a good job and the rest of the system still has a bit of life in it.
I’ll have a look at Demand and Twisted and get both sections done. Based up north Tyne and Wear. Cheers. |
12th Aug 2022 10:01am |
Stagshaw on the team valley have/had a good reputation for custom work and fabrication. Might be worth giving them a shout.
12th Aug 2022 4:05pm |
Good to know,
Cheers |
12th Aug 2022 4:17pm |
