Home > Technical > advice needed please |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
Possibly a clutch pressure plate spring broken loose. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
5th Aug 2022 8:12pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
I'm guessing that you're confused with your "in" and "out". A clutch is "in" when the pedal is up and "out" when the pedal is pressed. If I'm right in my guess, then likely causes are compressed springs in the driven plate or chatter in the gearbox.
What does it do if you select neutral on the transfer box and have it in a gear in the main box and repeat your test? If you switch off the engine with the main box in neutral and the clutch in (i.e., pedal up) do you get a noticeable sharp rattle as the engine stops? This is the usual symptom of a dying driven plate. Do you know how old the driven plate is (years/miles)? |
5th Aug 2022 8:43pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1581 |
I had a brand new 2.4 that rattled almost from new. It was as mentioned above knackered spring on the clutch plate
5th Aug 2022 8:55pm |
def110sw Member Since: 26 Jul 2022 Location: s west Posts: 6 |
thanks all
I am grateful I also think black wolf is right with his in/out description! Will do those other tests and re-report.... Thanks |
5th Aug 2022 9:30pm |
so tests done!
1. ''What does it do if you select neutral on the transfer box and have it in a gear in the main box and repeat your test?'' - answer: exactly the same thing 2. ''If you switch off the engine with the main box in neutral and the clutch in (i.e., pedal up) do you get a noticeable sharp rattle as the engine stops?'' - answer: the usual vibration of engine stopping (is that the oil centrifuge or something?? Anyway entirely as usual) then, when that has stopped, a much quieter but new rattle I had not previously noted - so probs yes.... Best get the clutch looked at... |
6th Aug 2022 5:29am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
The 'new rattle' when the engine has stopped is probably the EGR doing its normal cleaning cycle ie three 'chuggas' - you have a different problem if it stops making this noise!
HTH Keith |
6th Aug 2022 3:47pm |
No centrifugal filter on a.Puma. I fear your driven plate is on its last legs.
6th Aug 2022 8:57pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 809 |
Sounds similar to my issue, which as I was advised was the springs rattling on the clutch plate, so a new clutch solved it.
Have a look at the 2.4 CLUTCH REPLACEMENT - WHAT ELSE TO GET DONE? thread in PUMA TDCI. (Sorry, I don’t know how to link to a thread on my mobile). |
6th Aug 2022 10:35pm |
cheers all - will get it looked and and update once definite outcome!
7th Aug 2022 10:16am |
so had clutch replaced today - quick shoutout for great service at Country Rovers in Taunton
Prior to doing it the noise was a bit louder, but driving well, and still not intrusive at all... Was on last legs and needed doing++when opened up - so very glad I took it seriously thanks guys for advice! |
8th Sep 2022 4:42pm |
You're welcome, it is always nice to get feedback and learn that the advice has been useful.
8th Sep 2022 5:41pm |
