![]() | Home > Off Topic > anyone on here familiar with the gas regs? |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
here's the scenario.
old building with gas pipe running from basement up a riser located in the middle of the building to the roof. new boilers require a new / larger gas pipe........ only the riser needs to be vented as basement and top to atmosphere !!!! how do you vent the base of the riser to atmosphere when it both at basement level and in the centre of the building?......or is there a get out of jail clause? ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
6" waste pipe going to "outside"?
I'll grab me coat and stick to sparky things.... |
think you might be onto something - hopefully there's an easier solution but not sure what it is?
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1946 ![]() ![]() ![]() |
Venting a void containing a gas supply is only to prevent a gas build up that is permissible from a tightness test with appliances connected.
Multiply the width X height of the void (length is not important) Eg void is 300 x 300mm 0.3 x 0.3 = 0.09m square, no issues having any size larger. Commercial gas has a different set of regs. 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3475 ![]() ![]() ![]() |
Gas by itself does not explode, but when you vent it, it gives that oxygen needed to do
![]() Not familiar with gas regulations, but check if fitting gas detectors could be a solution. Have a detector installed on my boat, and the surveyor waived that the gas bottle is located inside the boat rather than outside. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 96 ![]() ![]() ![]() |
If the new pipe is installed in a duct the pipe would be vented at both ends, there’s also trac pipe cc product which is a pipe within an pipe system. But still check with your Gas Safe installer
thanks guys - and yes had thought about gas detection
![]() looking into that option. |
LPG has a different set of rules
No matter what pipe method you use the ventilation regs apply 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
even with gas detection?
