Home > Off Topic > anyone on here familiar with the gas regs?
Caterham
here's the scenario.
old building with gas pipe running from basement up a riser located in the middle of the building to the roof.
new boilers require a new / larger gas pipe........
only the riser needs to be vented as basement and top to atmosphere !!!!
how do you vent the base of the riser to atmosphere when it both at basement level and in the centre of the building?......or is there a get out of jail clause?
Confused
Post #960681 5th Aug 2022 3:54pm
6" waste pipe going to "outside"?
I'll grab me coat and stick to sparky things....
Post #960691 5th Aug 2022 4:36pm
Caterham
think you might be onto something - hopefully there's an easier solution but not sure what it is?
Thumbs Up
Post #960695 5th Aug 2022 4:52pm
Rashers
Maybe some form of forced ventilation?
I doubt very much there is a get out of jail clause with Gas. It's pretty tightly prescribed.
I am also an electrical engineer, not a Gas fitter but it is always a difficult conversation with a customer when what they have that works has to be changed to comply with current regulations when they want something changed.
Post #960721 5th Aug 2022 6:53pm
bear100
Venting a void containing a gas supply is only to prevent a gas build up that is permissible from a tightness test with appliances connected.
Multiply the width X height of the void (length is not important)
Eg void is 300 x 300mm
0.3 x 0.3 = 0.09m square, no issues having any size larger.
Commercial gas has a different set of regs. 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #960750 5th Aug 2022 9:34pm
Dinnu
Gas by itself does not explode, but when you vent it, it gives that oxygen needed to do Laughing
Not familiar with gas regulations, but check if fitting gas detectors could be a solution.
Have a detector installed on my boat, and the surveyor waived that the gas bottle is located inside the boat rather than outside. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #960765 6th Aug 2022 5:27am
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
If the new pipe is installed in a duct the pipe would be vented at both ends, there’s also trac pipe cc product which is a pipe within an pipe system. But still check with your Gas Safe installer
Post #960769 6th Aug 2022 6:06am
Caterham
thanks guys - and yes had thought about gas detection Thumbs Up
looking into that option.
Post #960780 6th Aug 2022 7:24am
bear100
LPG has a different set of rules
No matter what pipe method you use the ventilation regs apply 2016 Range Rover Autobiography 4.4 TDV8
Post #960798 6th Aug 2022 8:55am
Caterham
even with gas detection?
Post #960808 6th Aug 2022 10:21am
