Home > Puma (Tdci) > Puma 2.4 not starting ..... immobiliser???
Page 11 of 12 <123 ... 101112>
Ianh
Good to hear you got to the root of the problem, and nice tips on the ignition switch replacement.
Post #953591 25th May 2022 4:40pm
Simon765
Martin wrote:
If the rpm needle moves during cranking it probably isn’t the crank sensor.
The "shunt" is actually a bypass of the wiring of the immobiliser comms link through the instrument pack.
Land Rover did this themselves when the 2.2 was introduced.
You need to access the instrument pack connector, remove it and make a temporary link between pins 3 and 4 with the likes of a straightened out plain metal paper clip.
If it now fires, your problem is the immobiliser link and you have two options:
Send the instrument pack for repair of the soldering of the socket to the PCB (I can do this for you through my business) - or do it yourself if capable Smile
Alternatively dismantle the connector and remove pins 3 and 4 (light green and grey wires to both) and join them permanently. Or if you like, cut the light green and grey wires where they enter the connector and join the loom sides together permanently, bypassing the cluster.
This makes the comms link between the 10AS alarm/immobiliser and the ECU a single wire without the instrument pack in the circuit (as per the 2.2).
The instrument pack will now log a fault if diagnosed as it does not see an incoming signal from the immobiliser, but this does not affect the instrument pack or vehicle operation whatsoever.
Also I feel this is NOT a security issue as the immobiliser itself is not bypassed, and this factory design of "in and out" wiring via the instrument pack only means that the engine won’t start if the instrument pack is missing.
However a missing instrument pack would be no problem for a thief as bridging 3 and 4 (on the now easily accessible connector) restores the link, which is clear from the wiring diagrams.
I fixed a 2010MY basic spec Puma with this issue last week. It would crank, and the RPM needle moved, but an signal tester showed the ECU wasn’t firing the injectors at all. Bridging 3 and 4 allowed it to start straight away Cool
Tracked mine down thanks to this post, bridged 3 & 4 and it started first time👍 Is the instrument cluster issue some dry joints or is it something more involved? Just trying to decide which way to go to fix it. Also, if the cluster is repaired, is it a weakness that is likely to occur again?
Thanks
Simon
Post #960423 3rd Aug 2022 1:47pm
spudfan
Ireland
2.4 2008 Puma non start this evening. Tried two sets of keys and locked unlocked etc but nothing. Over the years it happened once or twice but always started with the lock/unlock fix. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #963083 27th Aug 2022 6:24pm
spudfan
Ireland
If I was coming to this in the normal course of events I'd be diagnosing a faulty solenoid on the starter motor. There is a click when the key is turned and then nothing. As the starter motor was replaced a few months ago I cannot see this being the problem. The replacement was a Bosch. I've a mechanic coming in during the week and like everyone else with this issue I'll be trying the fixes suggested here.
Strange how it can be working perfectly one day and then the next day just give up the ghost. 1982 88" 2.25 diesel
Post #963122 28th Aug 2022 9:17am
Ianh
I would check all the connections to that starter motor, given it was replaced a couple of months ago as they may have worked loose and are not fully connecting.
Also what symptoms were exhibited to cause you to replace the starter motor ?
Post #963125 28th Aug 2022 9:48am
spudfan
Ireland
It disintegrated! 1982 88" 2.25 diesel
Post #963131 28th Aug 2022 11:17am
Also worth checking for a faulty starter relay (under the o/s/f seat on a 2.4), if this fails there will be no power to the starter.
Post #963142 28th Aug 2022 12:55pm
spudfan
Ireland
Everything electrical works including the courtesy light. I will try the battery negative terminal disconnect. If it does not kick I will know it is something else and hopefully easily tracked down. Whistle 1982 88" 2.25 diesel
Post #963151 28th Aug 2022 1:22pm
Martin
Site Admin
Check the 30A fuse (undocumented fuse for starter solenoid) in the pair on the middle right of this photo.
Bottom right is ECU fuse, not related to this problem.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #963155 28th Aug 2022 1:56pm
spudfan
Ireland
I disconnected the negative terminal, left it off for a few minutes and then reconnected it. It still would not start. All I get is a "click" which makes me think it could be the solenoid or something else mundane! I will see what the mechanic thinks. 1982 88" 2.25 diesel
Post #963156 28th Aug 2022 1:57pm
spudfan
Ireland
Just checked this and it is fine, thanks. 1982 88" 2.25 diesel
Post #963157 28th Aug 2022 2:04pm
Ianh
spudfan wrote:
It disintegrated!
I think that’s a very reasonable reason to replace it Rolling with laughter
Post #963167 28th Aug 2022 4:40pm
spudfan
Ireland
https://www.defender2.net/forum/topic83510...rter+motor 1982 88" 2.25 diesel
Post #963171 28th Aug 2022 5:01pm
spudfan
Ireland
Back in action. The thing that sorted it (hopefully Very Happy ) was jamming the negative battery lead terminal as far down as it would go on the negative battery terminal, then tightening it up. 60 starts later over two days with two different sets of keys and starting first time.
I had removed the negative battery lead and reconnected it as suggested but to no avail as I stated earlier. I had the mechanic check all the technical stuff but all was O.K. He suggested putting the negative battery clamp as far down as it would go on the battery terminal before tightening it up and this seemed to do the job. So anyone else having this bother don't just attach the clamp to the terminal, force it down then tighten it. Sounds innocuous enough but it seems to be working for me. Any lapses and I'll let you know, but for now all is good. 1982 88" 2.25 diesel
Post #964284 7th Sep 2022 1:08pm
AndreB
Netherlands 2010 Defender 90 Puma 2.4 HT Galway Green
Non starter
Hello quys,
I have exacltly the same issue, crank but not firing. By reading all the topics I am quite convinced the solution is the "shunt".
I have a very basic technical knowledge but I must give it a try to get the life back in my beloved Defender.
Obvisously a very "dumb"guestion Whistle Ho can I get acces to the instrument pack connector? Is that one connected to the green immobilise module behind the speaker? Or do I need to access the instrument cluster?
Sorry for this.. Smile Had:
Defender 90 TD5 2001 - 225.000 km
Defender 110 TD5 - 2000 - 120.000
Have:
Defender 90 Puma 2.4 2010 - 211.000 km
Instagram: https://www.instagram.com/landrover_diary/
Post #999420 10th Jul 2023 8:43am
