Home > Puma (Tdci) > Unusual DPF fault fixed |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
Thank you very much for sharing this. I live on an island where getting motorway miles is impossible unless you take a ferry to the nearest larger mass of land. Hence most of the time I get the acronym for DPF as the Dreaded Particulate Filter, and not just for my Defender. However, but also confirmed through some threads on this forum, is that the DPF warning lights should never come on, even while performing an active regen. There are no clues that a regen is happening. Some claim that the engine changes sound... I never noticed anything.
Interesting about the latest ecu map being better. I do sometimes feel it kangaroo a bit when not yet warmed up and load on the engine is low. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
30th Jul 2022 1:12pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 730 |
Unfortunately your local specialist misled you. The orange and red DPF lights are warning lights indicating a problem. They do not come on during normal passive or active regeneration.
Little wonder your DPF was blocked. An expensive mistake, which hopefully is now resolved having found a fault. |
30th Jul 2022 2:02pm |
As Dinnu says, the orange and red DPF lights indicate that something is wrong and shouldn't come on at all in normal operation. The orange is a warning that the DPF is approaching full and that you need to take it for a 30 minute run to clear it. If you get a red then the DPF is already clogged and needs attention. This could be a forced regen that some diagnostic tools can initiate, or it could be terminal depending on the circumstances.
If everything is working as intended, there is no overt indication that a regen is taking place although again as mentioned, I can detect a change in engine tone when it's happening. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
30th Jul 2022 2:16pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 578 |
I recently had something similar. Dpf light illuminated following an immobiliser fault and many attempted starts. Turn out the egr had failed And was not recirculating. A forced regen would not work. A new egr a dpf flush and a software update and all has been good for about 6 weeks and 1500 miles
31st Jul 2022 7:17pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7905 |
Glad you got it all sorted in the end and good of you to post the issue for others to reference.
I too had 'DPF' issues and error codes that were NOT DPF issues at all. After discussions of replacing/blanking the DPF it turned out thanks to the aid of D2N a simple "Parameters Reset" via a Hawkeye sorted it all out. https://www.defender2.net/forum/topic78640.html?highlight=dpf James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
2nd Aug 2022 1:57pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17374 |
This is why I'm glad I have a 2.4 and do not intend ever to own a 2.2!
2nd Aug 2022 5:06pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20356 |
^^^^ +1 $W33T $0U7H3RN $UG4R
2nd Aug 2022 5:24pm |
Apart from above, which turned out not to be an issue (self inflicted from jump starting) we've had no issues whatsoever with the DPF and it does a lot of short journeys. It wouldn't deter me from buying another. James
2nd Aug 2022 5:35pm |
NeedForTweed Member Since: 02 Mar 2021 Location: Cumbria Posts: 10 |
It’s been a while and I have been meaning to post an update for some time. For those who said that an orange DPF light should always be viewed as problematic then all I can say is, yep, you’re right. Those ‘active regens’ I mentioned ultimately caused limp mode issues again. I checked the error codes and it turns out the MAF sensor was the culprit. I suppose it was hiding in the background all along but the ECU fault trumped it. Anyhow, I bought a replacement for £20 and fitted it before driving down to Goodwood for the revival. I live in north Cumbria so that’s a proper (brave?) test. You can probably guess where this is going….
The journey there was actually uneventful but the next morning the engine light came on after 5 min followed by limp mode. Checking the error codes told me it was the MAF again, and buying the £20 Chinese sensor was probably not a wise choice. As you can imagine, once I’d cleared the errors the drive home was a little stressful, but passed without any more issues. I then ordered the Hitachi part (£70 if I recall) and this solved the problem. Weeks went by without any dashboard histrionics until I needed to head down to a meeting in Manchester. Just an hour down the M6, fortunately at the start of the slip road to Lancaster services, the red oil pressure light came on! Well, that couldn’t be good so I popped it in neutral and coasted straight up to the car park and turned it off. I noticed a few new rattle sounds as I used a bit of throttle to park it, then shut down and called the RAC. Nothing obvious amiss under the bonnet so I assumed (correctly) it was the oil pump. Mine is an early 2.2 and there was a ‘soft’ recall to replace the early pumps that were known to be problematic. However, it was ‘soft’ so only main dealers knew about it. Turns out my car was a fleet vehicle in its early life so serviced independently, so it was never done and obviously I knew nothing about this recall either. I had the RAC take me and it to Braithwaites near Penrith to be assessed and repaired. I was expecting the worst but it was just the pump and turbo that were damaged in the end. Still a hearty repair bill but cheaper than a new engine. (I’d thoroughly recommend Braithwaites incidentally. Great garage). Anyhow, I won’t bore you with too much more, suffice to say that this was in Oct last year and 4000 miles later everything is still working well. I was seriously considering selling (or torching) it but, as my wife pointed out, that’s all the biggies sorted so we should keep it, at least for the winter. Let’s see what the future holds but it’s proven itself over the winter up here and is working its way back into our hearts…. Summary - don’t ignore the orange DPF light, and certainly check if you had the recall if yours is an early 2.2. |
8th Feb 2023 7:02pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1076 |
The DPF lights and what to to if they come on is clearly explained in the owner's handbook
8th Feb 2023 8:40pm |
Ha! Funny. You must have a different manual to me 😀
8th Feb 2023 11:15pm |
I always thought DPFs were introduced with MY 2012, so maybe they forgot to include such 'marginally' information in the 2011 booklet.
For reference --- DIESEL PARTICULATE FILTER (DPF) (AMBER) Illuminates when the DPF is approaching capacity. If this warning lamp illuminates, carry out the DPF regeneration procedure as soon as possible (see DIESEL PARTICULATE FILTER (DPF)). DIESEL PARTICULATE FILTER (DPF) (RED) Illuminates when the DPF is full. If this warning lamp illuminates, the vehicle should be taken to your Dealer/Authorised repairer as soon as possible DIESEL PARTICULATE FILTER (DPF) Diesel vehicles equipped with a particle filter have more efficient emission control. The particles in the exhaust gases are collected in the filter during normal driving. When the amber warning lamp illuminates (see 27, DIESEL PARTICULATE FILTER (DPF) (AMBER)), the filter requires a regeneration cycle to clean itself. This requires the engine to have reached normal operating temperature. Regeneration takes place automatically at an interval of approximately 300-900 km (190-560 miles) depending on driving conditions. Regeneration normally takes 10-20 minutes and is automatically requested by the engine control module if the vehicle is driven steadily, in high range, at vehicle speeds between 40mph to 70mph. It is possible that the regeneration process will occur at lower vehicle speeds, but the events may take a little longer at a 50 km/h (30mph) average speed. DRIVING SHORT DISTANCES OR IN COLD WEATHER If the vehicle is frequently driven short distances or in cold weather conditions then the engine may not reach normal operating temperature. This means that regeneration of the diesel particle filter does not take place and the filter is not efficiently cleaned. When the filter reaches a condition when a filter regeneration is appropriate and the current drive style is not appropriate, an amber warning lamp illuminates on the instrument panel (see 27, DIESEL PARTICULATE FILTER (DPF) (AMBER)). This is not indicating a fault condition with the vehicle and no dealership support should be required. Start regeneration of the filter by driving the vehicle, in high range, preferably on a main road or motorway. The vehicle should then be driven for approximately 20 minutes or more. When regeneration is complete the warning text is cleared automatically. Note: A small increase in fuel consumption may be noticed temporarily during regeneration. --- That's nothing, however, compared to a 40-page DPF manual Toyota provides |
9th Feb 2023 10:47am |
Sorry, I didn’t think you were serious. I’m not trying to provoke you.
Yep. I have the same text, (confusingly MY 12 incudes Dec 2011 vehicles) but I’m not sure you read the full message string. The manual was no help at all. As you have shown, the manual states that an amber DPF light ‘does not indicate a fault condition’ and no dealer intervention is required. Therefore, when my amber DPF light initially popped up all those months ago I assumed it was normal and typical of the way the tech had been integrated. It came on, then 30 seconds later went off. Fine. In fact, contrary to what the manual says, I now know that it was telling me there was a problem. Initially it was a misbehaving MAF causing the DPF issues but that was compounded by a wire coming loose in the ECU resulting in a red DPF light as the computer refused the request to regen when in an error state. Of course, I can’t expect an owners manual to cover every possible scenario, and the ECU fault is likely a very rare occurrence, BUT, the takeaway has to be that an orange DPF light should be seen as a problem needing investigating. The manual says the opposite. |
9th Feb 2023 3:10pm |
Ah, ok, no everything's fine I may have misunderstood some things.
Indeed an 'interesting' fault pattern and thanks again for sharing. Model years started around September the previous calendar year. Same with ours, which was built in September 2014, but I refer to it as 2015 in order to not confuse things even more... I think... well, never mind |
9th Feb 2023 4:59pm |
