Home > Technical > intermittent ETC fault |
Ahhhh I was just searching for this problem at lunch... Weird...
Checks 1) ABS sensors are correctly seated, connected and the wires are not broken. 2) Earth next to the ABS modulator can cause intermittent illumination of TC/ABS lights. 3) ABS modulator shuttle valve wiring intermittent connection, sometimes over bumps leading to illumination of TC/ABS lights and sometimes activation of ABS without brake pedal pressure. Hope that's a starter for 10 |
21st Jul 2022 8:08pm |
21st Jul 2022 8:14pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8152 |
Brilliant, thank you Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Jul 2022 5:12pm |
You're welcome James. Let us know when you sort the problem
24th Jul 2022 8:55am |
Still not sorted. Intermittent means it never fails when I have the time to look at it! I think it's wheel sensor issue. Cheers
11th Aug 2022 10:18pm |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1627 |
hi jst, strangely my neighbour asked for some assistance last week as his partners Hyundai i20 had both the Traction control and ABS light come on, we plugged it in and it said fault L/H rear wheel sensor he ordered one and we replaced it on Monday evening and sure enough the lights have now gone out, hopefully yours will do the same cheers Paul
12th Aug 2022 11:39am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
I’m having a similar issue (see post on maintenance thread).
I’ve replaced a suspect rear abs sensor and the abs shuttle valve thingy and lights (3 amigos) are still on. I was wondering if the fault has to be reset before the lights go out? Any advice guys and gals? Cheers, Will |
12th Aug 2022 5:21pm |
Hi Screbble, I can’t advise about LR but Ilona’s Hyundai cleared the lights once the sensor had been replaced cheers Paul
13th Aug 2022 8:04am |
Thanks Paul - I kind of thought that but also subconsciously wanted it to require a reset to prove the repairs had worked…
The replacement of the WABCO modulator solenoid switch thingy hasn’t changed anything, and to be fair the old one looked and felt fine, but at least I know that’s not the cause. It was fun changing it! Im now ‘hoping’ that my abs sensor isn’t in far enough… All this hoping it’s not the mega bucks abs modulator… Obviously I need to get it plugged in somewhere. Anyone got a Nanocom or similar in and around West Lancashire? Thanks Paul, Will |
13th Aug 2022 8:31am |
Can you not compare it with the other side? Darren
13th Aug 2022 10:46am |
Yes the plan is to do that today when the sun has started to go to sleep.
I’m hoping the OSR is further in! I have a second spare ABS sensor so will take the opportunity to replace that one at the same time - after measuring and photographing of course I’m also going to look at the ABS wiring, relays, connectors etc. and see what I can find… Wish me luck |
13th Aug 2022 11:04am |
Just compared both rear abs sensors in terms of ‘depth of insertion’ (sounds like a phrase from Carry on Landrovering) and they are the same - approx 20mm from the face of the orifice to the cable end of the sensor.
So that ‘kind of’ made me a little downhearted as that was unlikely to be the problem. I then tested all the fuses, relays, wires, connectors etc. on the ABS circuit and used contact cleaner along the way. Low and behold those flippin’ 3 amigos have vacated the instrument binnacle! Great news BUT not sure what (if anything) fixed it… They may be back |
13th Aug 2022 3:28pm |
Hi Screbble, that’s great news, sometimes that’s all it takes unplug a good clean and reassemble, hopefully they have been banished for good cheers Paul
14th Aug 2022 8:30am |
