Home > Maintenance & Modifications > flywheel help - plus modified flywheel idea
famousdefender
United Kingdom 2005 Defender 110 300 Tdi PU Alpine White
Advice please! I'm rebuilding my 110 ROW 300TDI in the Caribbean. Parts are a mission to get, especially heavy items! I'm converting it to EV (don't get mad I still have a second diesel 110)
I'm bolting the motor to the Gbox - transfer box and it will all be reversible in the future if it all goes ti*s
1: My current flywheel has lots of hairline cracks, has had for years! Question - how dangerous or risky is it to keep using it? Getting a new on here is tres expensive.
2:are there any lightweight flywheels manufactured for a 300? it's going to be EV so having extra mass is a negative really - electric motor has lots torque + it will mostly stay in 3rd anyway. I know theres alloy ones made for the early v8 range rover (made by Fidanza) that are compatible with v8 9.5 inch clutch (459733 part number) Can a v8 clutch and flywheel be fitted to 300 box?
Post #959033 20th Jul 2022 6:15pm
Dinnu
You may face the flywheel and see if the cracks are only surface deep, I believe there are specs on minimum thickness... but that is to make it work with the designed engine. EV is a different story. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #959043 20th Jul 2022 7:06pm
LR90XS2011
Why do you need a flywheel are you keeping the clutch plate to drive the gearbox?
If you do need one you may get a flywheel at a reasonable price from LOF DEFENDER 90 TDCI XS,
Post #959045 20th Jul 2022 7:14pm
famousdefender
Hi, yes keeping it all original minus the engine, want to retain high and low and gear changes etc, also I can't afford to go Tesla or custom transfer box. I'm bolting straight to the gearbox, all reversible.
lighter the flywheel the better. Can a v8 9.5 inch clutch fit a 300 tdi? if so there's aloy flywheels out there!
Post #959089 21st Jul 2022 11:47am
