Home > Maintenance & Modifications > flywheel help - plus modified flywheel idea |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3431 |
You may face the flywheel and see if the cracks are only surface deep, I believe there are specs on minimum thickness... but that is to make it work with the designed engine. EV is a different story. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
20th Jul 2022 7:06pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3646 |
Why do you need a flywheel are you keeping the clutch plate to drive the gearbox?
If you do need one you may get a flywheel at a reasonable price from LOF DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
20th Jul 2022 7:14pm |
famousdefender Member Since: 20 Jul 2022 Location: hampshire Posts: 4 |
Hi, yes keeping it all original minus the engine, want to retain high and low and gear changes etc, also I can't afford to go Tesla or custom transfer box. I'm bolting straight to the gearbox, all reversible.
lighter the flywheel the better. Can a v8 9.5 inch clutch fit a 300 tdi? if so there's aloy flywheels out there! |
21st Jul 2022 11:47am |
