Home > Maintenance & Modifications > AC or no AC |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Left dial controls temp. Right dial controls fan. Instagram @defender_ventures
Empire Tuning - Agent |
17th Jul 2022 3:39pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5771 |
Correct. Need to use both dials. And soon you will have the coldest set of vehicle keys in the world, and possibly one cold knee.
Open your flaps |
17th Jul 2022 5:14pm |
Poulstonb Member Since: 30 Jun 2022 Location: Styal Posts: 88 |
Thanks guys thought I was doing something wrong
Does it have a ac system as other more modern vehicles has in that it needs regassing |
17th Jul 2022 8:11pm |
It may need regassing after a few years or if you’ve had leak. Mine has been good for many years, but don’t really use it. Couple of times a year just to keep the oil going around the system.
17th Jul 2022 9:29pm |
So…..
I took it to be re gassed and they’ve said I need 2 new valves where the gas is put in and a new condenser radiator. Is this a fix at home ? |
18th Jul 2022 3:57pm |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
Everything can be fixed at home... but on a pressurised system I'd leave it to the Pros
18th Jul 2022 5:46pm |
Price up a replacement condenser first they are not cheap. The valves they are talking about are pennies (very little money). How bad is your condenser?
18th Jul 2022 8:57pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
If it needs new valves and a new condenser there will be no pressure/gas left so a simple job.
Last year I fitted a larger aftermarket condenser - simple 30 minute job. Still cold as ice this year Same as this one https://www.ebay.co.uk/itm/194353227788. > 110 XS Double Cab |
19th Jul 2022 7:48am |
