Home > Maintenance & Modifications > Swollen nuts! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17461 |
This is a well-known problem and has been discussed many times before on the forum. Alternatives include aftermarket (posh, expensive) wheel nuts, removing the vanity cover, or using a 28mm socket.
It is unlikely that WD40 would prevent rust long term, there are better anti-rust fluids you could soak your new nuts in before use. I wonder sometimes how widespread this problem is. My Disco2 is twenty years old and hasn't had the problem, my Defender is 15 years old and hasn't had the problem. Perhaps it is a QA issue which means that some nuts corrode more than others, or maybe atmospheric. I'd also question why they "had" to be replaced. Swelling doesn't stop you taking them off, and it isn't a safety issue. Were you asked beforehand if you wanted replacements? I imagine from a dealer that they are absurdly expensive for mediocre quality wheel nuts. |
16th Jul 2022 10:26pm |
paul 123 Member Since: 10 Jul 2022 Location: norwich Posts: 86 |
take the covers off then it cant happen . i had the same problem on the wifes disco 3 replaced the nuts with basic ones with no covers .
17th Jul 2022 4:40am |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 289 |
Had the same problem; my solution from another thread :
https://www.defender2.net/forum/topic82605.html Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
17th Jul 2022 6:55am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3430 |
I had what I think where NRC7415 on my old 90. No fancy cap. The zinc plating got dull over time but are still perfectly useable. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
17th Jul 2022 7:13am |
