Home > Maintenance & Modifications > A Better License Plate Mount
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Hey folks. So as a new Defender ower, and a maker, I always thought it was crazy why the Land Rover engineers and designers did not think to leverage the license place light mount/plinth to ALSO be the actual mount for the license plate? I am sure there was a reason...
However, I am trying to avoid drilling more holes in the back of my Defender. So I took some measurements and jumped into my cad software to see if I could come up with something that could work with the existing Plinth and light.
The concept I have here is a 3mm thick metal mount that would be sandwiched in between the light and the plinth. Additionally, I might cut down my plinth in half so it does not stick out so far. Anyway thought I would share. I have a prototype being made and will report how it goes.
 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #958052 12th Jul 2022 5:51pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Are the plinth fixings strong enough to take the loading and secure enough to stop and vibration/rattle causing damage to the paintwork behind?
Post #958057 12th Jul 2022 6:08pm
Soulrider911
That is a good point. I am yet to inspect the actual plinth. However, the stock one is pretty long... the longer it is the more vibration it could conduct. However, my assumption is it would have to be vibrating a lot to go so far as to crack paint?
Two potential remedies to minimize vibration.
    - Shorten the plinth as much as possible
    - Add a foam vibration film/spacer much like what the light has between it and the plinth.
 1989 Defender 90
Post #958062 12th Jul 2022 6:26pm
Balvaig
Most UK licence plates are now stuck on with double sided tape. No need to drill holes, no vibration and generally not much paint damage.
Post #958063 12th Jul 2022 6:28pm
Soulrider911
Interesting, I wish we could do that in the US 1989 Defender 90
Post #958064 12th Jul 2022 6:29pm
Retroanaconda
Why not just screw the plate to the vehicle? You can see the two holes from the original plate in the body panel below your light.
Post #958074 12th Jul 2022 7:05pm
Soulrider911
Right, unfortunately, all those holes don't match U.S plate mount Sad
Here is a prototype my buddy fired off. This would mount directly to the body, and most likely avoid the vibration issue altogether.
 1989 Defender 90
Post #958081 12th Jul 2022 8:08pm
Retroanaconda
I’d just drill new holes to be honest, but nothing wrong with a bit of over-engineering 👍🏻
Post #958083 12th Jul 2022 8:14pm
Soulrider911
Totally true. Over-engineering is a bad habit of mine Smile 1989 Defender 90
Post #958084 12th Jul 2022 8:25pm
Is there a reason why you can’t use adhesive tape or other form of bonding? (Avoiding drilling holes).
Is it to change it over or is there a specified US law that applies to it? Chillin In The Backwoods🇬🇧🇺🇸
Post #958088 12th Jul 2022 8:51pm
discomog
I read somewhere that you can now wrap license plates in CA. I know these are designed specifically for front bumpers but is this an option for you?
https://licenseplatewrap.com/ Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #958108 13th Jul 2022 7:27am
The Zee
Really like the inovation here - drilling holes in the body is something every owner hates doing.
The idea of a bracket, using the plate light plinth, I like. In aluminium would be perfect.
On a side note, I trimed my plate light plinth to the same depth as the 95mm lamp plinth, was really easy to do with a manual mitre saw set at 90 degrees, some masking tape, and a dose of caution. Zaid-M
www.DefencePhotos.com
Post #958210 13th Jul 2022 8:43pm
Soulrider911
Plastic prototype. So after playing with some materials I think. Plastic-based would be best… The reason is plastic absorbs vibration, and mealy generally conducts it.
Here is my first test. This is PETG, which is a darn strong plastic compound with decent heat tolerance. Going to mount it up and test… see how it goes
 1989 Defender 90
Post #958385 15th Jul 2022 2:06am
bear100
Now That looks awesome!!! Bow down 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #958391 15th Jul 2022 6:01am
The Zee
That looks really well thought out, better than stainless steel, and less likly to create galvanic corosion problems. Thumbs Up Zaid-M
Post #958408 15th Jul 2022 10:34am
