Home > Puma (Tdci) > Assembling an in-car toolkit, advice welcome. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4655 |
Looking forward to the update. Then again you are never really finished as you always see something else that you might need...sometime 1982 88" 2.25 diesel
14th Jul 2022 5:08pm |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
I'll be sure to post it up. I've just ordered the shadow foam so if I forget something after its all cut and laid out I'll be more than a bit annoyed
14th Jul 2022 5:44pm |
The cut out foam is a great idea. With the foam you always know if you have packed everything away or not. Cuts down on the possibility of leaving something under the vehicle or even worse in the engine bay! 1982 88" 2.25 diesel
14th Jul 2022 5:52pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1076 |
Good point. Someone should have told the JLR dealer's apprentice about it, before he forgot this spanner on my brake I drove 20 minutes with this. Luckily I don't trust people who charge too much for their work, so I had a look underneath. Brake fluid splilled all over the place Click image to enlarge |
14th Jul 2022 7:13pm |
Just finished my spanner list. Have combined suggestions from the forum, a couple of other forums, Tom Shepperd's list and a couple of YouTube videos as well as checking the vehicle. Obviously this isn't every singlee spanner needed, rather its the most common and critical ones. When in doubt about whether an odd size was needed I searched for "Puma Defender XXmm spanner" and quickly found some weird sizes in use in critical areas. Quite a few posts from @Blackwolf too saying that Land Rover used a lot of non-common sizes on the Puma.
Here's the list: Combination spanners: 8mm 10mm 11mm (brakes) 12mm 13mm 14mm 15mm 17mm 19mm 9/16" Adjustable spanner: 8" long adjustable Sockets: These would obviously match the spanners except for: - The 9/16" as I'll use my Difflock prop shaft tool to work with that spanner. -My 52mm hub nut socket doesn't need a spanner -An 8mm fixed Allen key type socket for MT82 drain and filler plugs -I have a 1/2" square drain plug socket for axle filler/drain and transfer box drain (I know I can use the 1/2" wheel brace I have but I prefer to use a tool instead of using a bare 1/2 extension or handle - the one I have is driven by a 3/8" ratchet so it means I can have all the sockets in 3/8") A lot of people have mentioned packing a 1/4" drive socket set too. I actually have a little set in a box that I could donate to the car, but am curious as to why? 6 or 7mm would be handy for hose clamps but I can't think of any other reason to carry a full set of 4-13mm 1/4" sockets... plus the ratchet... plus extensions. Any thoughts? |
14th Jul 2022 10:23pm |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 289 |
Maybe since 1/4" drive rachets are slimer / smaller headed they can access fittings in a tight location with less strain on the hand due to being lighter? Zaid-M
www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
14th Jul 2022 11:04pm |
So the five on the right are Tx 10 - used for stop screws in the channel rails of our camper conversion Tx 15 - I replaced various of the original Pozi screws with Torx headed ones Tx 20 - replaced some of the push-through pins of wheel arch eyebrows and inner trims with Torx head screws, too Tx 30 - many screws of panels and trim Hex 4 - forgot what this was for, but must be important enough to have it included |
15th Jul 2022 6:34pm |
thank you very much for checking these.
More tools pulled out of the spares and more ordered. Going to take a couple of weeks but should be a nice little kit. |
19th Jul 2022 11:07am |
I think you are going to need a bigger Land Rover to carry it
Why not add one of these. They are good for reaching awkward https://www.ebay.co.uk/itm/302760224923?ha...Sw~KNiQy6v 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
19th Jul 2022 11:16am |
not a bad shout at all, thank you
I'll get the primary tools together (about 70% of them are here now, the rest to follow in the next couple of weeks) and will post up pics for a final verdict before I commit with the shadowfoam. |
22nd Jul 2022 11:36am |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 |
Based on experience of having it happen to me, may I suggest having two 13mm open-ended spanners - for the clutch pedal locknuts.
Yes, I had them come loose, in France, towing the caravan in rush hour Lyon traffic. It is merely a coincidence that I’d had a new clutch fitted by a main dealer just days before. Apparently… I didn’t have two 13mm spanners, just one, so threadlock came to the rescue… Dave Green Goddess - 1998 Defender 110 300tdi |
22nd Jul 2022 9:06pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
2 x 9/16 spanners also, for prop nut/bolts, it can come in real handy to take a prop off if needs must (UJ crapping itself, for instance)!
A 14mm will work, but not ideal. |
23rd Jul 2022 5:27am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1999 |
Gasket, If your tool kit gets any bigger you are going to need one of these to carry it
23rd Jul 2022 10:40am |
Class 1982 88" 2.25 diesel
23rd Jul 2022 10:42am |
