Home > Maintenance & Modifications > Defender Puma 2.2 TDCI Coolant Change Steps
JohnP2222
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Please could someone list, or point me to, steps to change the coolant?
I'm pretty good at vehicle maintenance ... but when the radiator does not have a cap ... I'm unsure even where to add new coolant!
Thanks in advance.
John P
Post #957766 9th Jul 2022 11:56am
spudfan
Ireland
You top up/refill at the expansion tank on the bulkhead. It is circular and a pale non see through plastic. It is on the driver's side on the bulkhead.To fully drain the system there are two small pipes on the chassis rail inside the chassis rail at the front passenger wheel. This is for a 2.4 RHD Pumas. Don't know if LHD are the same. This is where you drain the system. Or you could just undo the lowest hose you can find and let it drain out. You will get most of it out. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #957774 9th Jul 2022 2:11pm
JohnP2222
Thank you. That I can do!
Post #957781 9th Jul 2022 4:54pm
spudfan
Ireland
Check these out
https://www.aulro.com/afvb/90-110-130-defe...bleed.html
https://www.defender2.net/forum/topic72341.html 1982 88" 2.25 diesel
Post #957791 9th Jul 2022 6:53pm
Dinnu
And this:
https://www.defender2.net/forum/post372623.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #957796 9th Jul 2022 7:13pm
