Home > Maintenance & Modifications > Defender Puma 2.2 TDCI Coolant Change Steps |
JohnP2222 Member Since: 09 Jul 2022 Location: Gloucester Posts: 2 |
Please could someone list, or point me to, steps to change the coolant?
I'm pretty good at vehicle maintenance ... but when the radiator does not have a cap ... I'm unsure even where to add new coolant! Thanks in advance. John P |
9th Jul 2022 11:56am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4636 |
You top up/refill at the expansion tank on the bulkhead. It is circular and a pale non see through plastic. It is on the driver's side on the bulkhead.To fully drain the system there are two small pipes on the chassis rail inside the chassis rail at the front passenger wheel. This is for a 2.4 RHD Pumas. Don't know if LHD are the same. This is where you drain the system. Or you could just undo the lowest hose you can find and let it drain out. You will get most of it out. 1982 88" 2.25 diesel
9th Jul 2022 2:11pm |
Thank you. That I can do!
9th Jul 2022 4:54pm |
Check these out
https://www.aulro.com/afvb/90-110-130-defe...bleed.html https://www.defender2.net/forum/topic72341.html 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
9th Jul 2022 6:53pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3387 |
And this:
https://www.defender2.net/forum/post372623.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
9th Jul 2022 7:13pm |
