![]() | Home > Maintenance & Modifications > Clutch pedal assist |
thomson_adam Member Since: 07 Dec 2021 Location: Cleveland Posts: 151 ![]() |
I’ve got the stop bolt wound in a far as it will go and still sticking
I’ve ended up adjusting the height by 10mm and it’s not much better |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
It’s been a while, but I don’t think I had t adjust the bolt much at all to fix mine. 2007 110 TDCi Station Wagon XS
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 ![]() ![]() ![]() |
I had the same issue but found after about a week of driving the pedal seem to self cure the sticking problem. Was a bit hairy at times though using the clutch! 15 plate 2.2SW XS
Oh really ? I have raised the clutch pedal as it was quite low (130mm) and I’ve used a longer stop bolt but it doesn’t feel like there’s enough travel. I may wind out the stop bolt and see if it settles down
