Home > Maintenance & Modifications > Clutch pedal assist
Page 2 of 2 <12
Bluest
I had that problem, my pedal actually stuck down a few times which was a bit startling. I contacted LOF and they said to adjust the stop bolt, which has fixed it for me. 2007 110 TDCi Station Wagon XS
Post #957014 1st Jul 2022 7:45pm
thomson_adam
I’ve got the stop bolt wound in a far as it will go and still sticking
I’ve ended up adjusting the height by 10mm and it’s not much better
Post #957019 1st Jul 2022 8:36pm
Bluest
It’s been a while, but I don’t think I had t adjust the bolt much at all to fix mine. 2007 110 TDCi Station Wagon XS
Post #957022 1st Jul 2022 8:56pm
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I had the same issue but found after about a week of driving the pedal seem to self cure the sticking problem. Was a bit hairy at times though using the clutch! 15 plate 2.2SW XS
Post #957095 2nd Jul 2022 5:49pm
thomson_adam
Oh really ? I have raised the clutch pedal as it was quite low (130mm) and I’ve used a longer stop bolt but it doesn’t feel like there’s enough travel. I may wind out the stop bolt and see if it settles down
Post #957398 5th Jul 2022 8:07pm
Page 2 of 2 <12
