![]() | Home > My New Defender (L663) > ARB Compressor in L663 |
KarimAsaad Member Since: 28 Jun 2022 Location: Dubai Posts: 2 ![]() ![]() |
I need help finding a way to mount a ARB compressor in my New defender MY2022
FLwolverine Member Since: 27 Jun 2022 Location: Florida Posts: 5 ![]() ![]() |
Engine bay mount:
https://lucky8llc.com/collections/defender...ressor-kit |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
Unless you bought the ARB unit, I would consider the new TJM unit. Got both and will definilty fit the TJM to my L663. m
GrouseK9 Member Since: 09 Aug 2021 Location: Austin, Tx Posts: 16 ![]() ![]() ![]() |
That's actually a great spot for it! I like it better in that location than taking up the limited boot storage as some have put it. I have my Trigger 4 Channel controller in that spot. I use it to run all my power without needing to poke holes thru the firewall each time. I kinda wish I had more space to add the compressor as well!
Huwrhys Member Since: 27 Mar 2024 Location: Hornchurch Posts: 134 ![]() ![]() |
I wanted just the mounting brackets from this company which were priced at £120, however the postage and taxes were an additional £352 ![]() I’ve sent an email with the expectation that it’s an error. Anyone live in New York State and able get a cost to post to Uk? Cheers Huw 24MY D300 130 X-Dynamic HSE Santorini Black |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1433 ![]() ![]() |
I got my ARB twin compressor mount from New Defender Mods. Really well made and easy to fit.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
Hi Moo
Thanks for your response mate but the twin compressor is a bit too much for my needs and pocket. (Unless the wife has taken her eye off her purse). I need to increase both front and rear by 13psi to tow and drive fully loaded. Therefore I need this ability almost constantly when touring in Europe. The pressures are up and down each time I tow so very often. The lucky8 mount is fine for my needs but the post/ taxes are stupendous. I can get the twin unit for about £320 plus the hose £53 and trigger/ connector £34. The extra £225 just ruins the deal a bit for her indoors. That’s why I looked at the cheaper option which I could do all in with a bit of shopping around for about £360 plus the postage of the brackets. Which is why I’m here trying to find someone who’ll look into the post options. 24MY D300 130 X-Dynamic HSE Santorini Black Last edited by Huwrhys on 26th May 2024 3:31pm. Edited 1 time in total |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
You can also mount it under the spare wheel, kit available from PowerfulUK
![]() Click image to enlarge ![]() Click image to enlarge that would be my preferred choice. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
I have the lock on the spare so a bit awkward for me. Also it’s the twin which is way beyond my needs. 24MY D300 130 X-Dynamic HSE Santorini Black
The rear upper panel can be converted into a storage box, but not sure a single ARB would fit in there?
![]() Click image to enlarge Alternatively, get a Molle kit and mount it inside? ![]() Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
The cars a tow car rather than an off roader. The tucked away position in the engine bay worked because I don’t lose any internal space. The upper storage boxes from Plumb are tiny (and pricey), so much so the girl presenting the video tried to get her water bottle in and it wouldn’t fit. Thanks for your suggestions though. 👍🏻 24MY D300 130 X-Dynamic HSE Santorini Black
You can always just mount single compressor on it.
![]() I also have a few things I want from Lucky8 and possibly Saltek. I'm currently planning to be in the US middle of June so will get them delivered to my hotel. If not I have lots of colleagues back and forth, so often get them to bring stuff back. If I do go, I'll let you know. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
What a great offer Moo. Very interested mate. 👍🏻👌🏻
Thanks for your help. 24MY D300 130 X-Dynamic HSE Santorini Black |
No worries. I'll keep you posted.
