Home > Expedition & Overland > Tie-Down Rings Hannibal Roof Rack
MattyEssex
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Indus Silver
After some help - ideally need to get some tie down rings to secure items
On roof rack.
Looking at top of roof rack I can see round holes in the runner that I presume the bolts heads go through.
Can anyone help with the Tie-Down rings suitable, ideally
To take rachet strap hook.
[/img]
Post #955385 13th Jun 2022 8:20pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
The rails should be T-slot channel and accept the head of an M8 (13mm) bolt. Something like these should work:
https://www.flatdoguk.com/rack-tie-down-rings---black~2530
Be careful though as you may find that the ratchet strap works the eye loose. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #955392 13th Jun 2022 9:16pm
MattyEssex
Great thanks I have ordered from amazon as the ones referenced were out of stock.
https://www.amazon.co.uk/dp/B09H5GLBHN?psc...yp_imgToDp
Just need to have a look to see how these insert into the rail.
Actually just noticed these have square bottom and not bolt head that would fit through the hole .... hmmm
Post #955397 13th Jun 2022 9:43pm
Likeomg
I bought some black stainless ones from accu,
M8 then get a big thick washer too otherwise you can damage the channel I have about 6 up there at any given time
Can be a pain to get the head to slot into some of the channels but if you slightly round them it makes it easier…
If i remember tomorrow I can grab some pics
Post #955407 13th Jun 2022 10:47pm
jst
I enlarged the channel to get the bolt head through circular top hole. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #955549 15th Jun 2022 9:21am
