![]() | Home > Expedition & Overland > Tie-Down Rings Hannibal Roof Rack |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 868 ![]() ![]() ![]() |
The rails should be T-slot channel and accept the head of an M8 (13mm) bolt. Something like these should work:
https://www.flatdoguk.com/rack-tie-down-rings---black~2530 Be careful though as you may find that the ratchet strap works the eye loose. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
MattyEssex Member Since: 23 Jul 2021 Location: Essex Posts: 77 ![]() ![]() ![]() |
Great thanks I have ordered from amazon as the ones referenced were out of stock.
https://www.amazon.co.uk/dp/B09H5GLBHN?psc...yp_imgToDp Just need to have a look to see how these insert into the rail. Actually just noticed these have square bottom and not bolt head that would fit through the hole .... hmmm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
I bought some black stainless ones from accu,
M8 then get a big thick washer too otherwise you can damage the channel I have about 6 up there at any given time Can be a pain to get the head to slot into some of the channels but if you slightly round them it makes it easier… If i remember tomorrow I can grab some pics |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8220 ![]() ![]() ![]() |
I enlarged the channel to get the bolt head through circular top hole. Cheers
