Home > Technical > Missing plug - 300TDI/R380 |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Wading plug hole, only plugged for deep water crossing 02' 110 TD5 Double Cab Rebuild Thread
12th Jun 2022 7:56am |
Adyonline Member Since: 11 Jun 2022 Location: Norfolk Posts: 16 |
I'm not planning to do any of that - thank you!
12th Jun 2022 7:59am |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 822 |
There should be a similar hole at the front of the engine in the bottom of the timing belt housing.
The bell housing one is used to lock the engine at tdc when doing the timing belt. There's an extra slot in the flywheel that the locking pin engages with. |
12th Jun 2022 12:42pm |
Thank you, yes, there's another unplugged hole in the timing belt housing.
14th Jun 2022 7:34pm |
ERC7295
Put them in in the morning before you go playing in muddy puddles and ponds. Take them out at the end of the day. |
14th Jun 2022 8:54pm |
