Home > Maintenance & Modifications > Main fuse box feed |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17231 |
Inside the cab.
6th Jun 2022 7:43pm |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 324 |
There’s a useful thread with photos here…
https://www.defender2.net/forum/topic61763.html If you leave the original (disconnected) cable in place then it’s not obvious that it’s been rerouted. |
6th Jun 2022 8:01pm |
The typical route is across the back of the seat box:
Click image to enlarge More details here: https://www.defender2.net/forum/post776416.html#776416 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Jun 2022 9:29pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 558 |
Thanks JPE and LandRoverAnorak for detailed replies, just what I was looking for.
I'm not buying a ready made kit, I can make up a length of cable with terminations myself. Another solution I'm investigating. The idea of this modification is to keep the alarm powered if the feed is cut. The alarm can only draw a few amps therefore only needs a much thinner and easier to route cable. I'll post details when I'm done. |
7th Jun 2022 9:48am |
If your Defender is XS spec it is likely (though not guaranteed) that it has a BBUS fitted, which will sound if the battery cable is cut provided it hasn't been nobbled beforehand, so to that extent keeping the alarm powered may do more harm than good (you'll just prevent the BBUS from sounding).
Depending on year there is a mode which is very advisable to take a second feed to the 10AS unit to eliminate the "indicator light fuse vulnerability" (incorporated into the dash harness on later models). It is also essential to do something to protect the BBUS, since Landrover in a moment of design genius placed it in a position where it can be access from outside the vehicle. If you do these two modifications, it doesn't really matter if someone cuts the battery cable, the alarm will sound. |
7th Jun 2022 4:32pm |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 323 |
This is a great idea. I think I'll be doing the same now, thanks for sharing. 4.0 V8 Defender 90
My Instagram |
7th Jun 2022 5:05pm |
Thanks for the insight. I was sort of heading in that direction. My Defender does have a BBUS (not tested yet) which is protected by a few extra layers of security. I'm not aware of the indicator fuse vulnerability, please PM me with the details so I can figure out the best way to provide an extra power feed to the alarm controller. |
7th Jun 2022 8:24pm |
Have a look at this thread from aeons ago, it discusses the mod:
https://www.defender2.net/forum/topic35353.html It describes the official mod and what it does. Later vehicles had the mod incorporated into the dash harness so don't need it. All this info is in the public domain so no need for secrecy (and you can bet the thieves know it). |
7th Jun 2022 9:15pm |
