![]() | Home > V8 > Temperature Gauge |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
Mismatch between sender and gauge?
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 879 ![]() ![]() ![]() |
As in it has the wrong sender fitted in the engine? Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Yes or wrong gauge for sender etc.
Righto. I’ve ordered a new sender in case. It’s the original factory gauge. Charlie
mediamab Member Since: 01 Dec 2021 Location: Matlock Posts: 58 ![]() ![]() ![]() |
Hi, I’m having exactly the same issue with my v8 with original gauge. Did the new sender help? Do you know the part number?
Many thanks!! |
edo Member Since: 20 Aug 2018 Location: Devon Posts: 370 ![]() ![]() |
Thread resurection!
I have similar. Needle only just registers. Thermostat is good and car gets up to temp ok. Changed sender no joy.... |
Did this fix the issue? Mine is just with a specialist having the carbs refurbished, and he's having a look to see if its getting to temp which would point to the guage as the thermostat is new... |
