Home > Maintenance & Modifications > Spot light wiring |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3689 |
You might find that the wiring is already there. On mine it was routed down the driver side wing, near the top. Then down the side of the grille to the lights. Have a look, especially if they’re are cables connected to the back of the switch there is a good chance that the loom is already in.
31st May 2022 5:08am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5790 |
I don’t think there is a standard LR loom. The ones I’ve seen/owned have looked hand crafted, and fitted a relay in the battery box.
31st May 2022 6:16am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17548 |
The genuine switch is a push-button switch not a toggle switch, but I guess that's probably what you mean. There is unlikely to be any wiring already present IMO, I think if you bought a genuine driving light kit you'd get a largely-finished harness in the kit but I've never seen a genuine pre-manufactured harness available separately. It's not hard to make one up. |
31st May 2022 8:07am |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
I would guess almost any of the heated screen looms would work (but probably want smaller fuses for spots). wiring to the switch (plug in to yours), and a relay to locate somewhere with probably long enough wires to get power to the grill (if not then extend) but I'd be amazed if someone hadn't put together a specific kit
1st Jun 2022 10:13pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
stc53208 is the part number for a genuine spot light loom
See also https://www.defender2.net/forum/post468727.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
2nd Jun 2022 2:24pm |
£275 for the harness! Wow, it is no surprise that it is not widely known about!
2nd Jun 2022 3:56pm |
I have one on mine, fitted several years ago, I'm sure I paid a LOT less back then One on ebay just now for £150 or best offer - you may get a bargain!!! https://www.ebay.co.uk/itm/175149025807?ha...SwcYJiAndR Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
2nd Jun 2022 4:16pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2270 |
That not a bargain ! 🤔😯
You'll need a relay, some wire, a switch connector and some terminals for the LR switch, a fuse and holder and a couple of econoseal connectors to make a tidy connection at the lamp. Google spotlamp wiring diagrams, the net is awash with them. I'd be surprised if you spent more than £20 to do the job. HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
2nd Jun 2022 4:50pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3789 |
Thanks all...
I'm not paying £150... In the same respect I'm colour blind so understanding wiring diagrams are a pain.. May enlist my 11 year Old son to help. Thanks all. |
4th Jun 2022 7:00pm |
Just a thought....
Can I use an amazon generic kit... and use the plug that goes in the back of my switch? So a kit like this Click image to enlarge Then cut the switch off and use this into the back of the oem switch? Click image to enlarge I still need to be able to do this but for £20 looks like it would do the same job? |
4th Jun 2022 8:29pm |
Yes you could 👍
5th Jun 2022 8:37am |
