Home > Maintenance & Modifications > Spot light wiring
Stacey007
Spot light wiring
Hello
I have the original spot light switch in my tdci (a rocker switch with lights (2) on..
Now I have a a frame bar with two spot lights, I would like to use this switch.
Is there a plug and play wiring set for this thar will connect to the switch, a relay , fuse and wiring?
Thanks
Post #954099 30th May 2022 7:28pm
Co1
You might find that the wiring is already there. On mine it was routed down the driver side wing, near the top. Then down the side of the grille to the lights. Have a look, especially if they’re are cables connected to the back of the switch there is a good chance that the loom is already in.
Post #954116 31st May 2022 5:08am
landy andy
I don’t think there is a standard LR loom. The ones I’ve seen/owned have looked hand crafted, and fitted a relay in the battery box.
Post #954118 31st May 2022 6:16am
Re: Spot light wiring
Stacey007 wrote:
...a rocker switch with lights (2) on...
The genuine switch is a push-button switch not a toggle switch, but I guess that's probably what you mean.
There is unlikely to be any wiring already present IMO, I think if you bought a genuine driving light kit you'd get a largely-finished harness in the kit but I've never seen a genuine pre-manufactured harness available separately.
It's not hard to make one up.
Post #954131 31st May 2022 8:07am
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
I would guess almost any of the heated screen looms would work (but probably want smaller fuses for spots). wiring to the switch (plug in to yours), and a relay to locate somewhere with probably long enough wires to get power to the grill (if not then extend) but I'd be amazed if someone hadn't put together a specific kit
Post #954363 1st Jun 2022 10:13pm
MartinK
stc53208 is the part number for a genuine spot light loom Smile
See also https://www.defender2.net/forum/post468727.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #954419 2nd Jun 2022 2:24pm
£275 for the harness! Shocked Wow, it is no surprise that it is not widely known about!
Post #954427 2nd Jun 2022 3:56pm
MartinK
Smile
I have one on mine, fitted several years ago, I'm sure I paid a LOT less back then Wink
One on ebay just now for £150 or best offer - you may get a bargain!!! https://www.ebay.co.uk/itm/175149025807?ha...SwcYJiAndR Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #954429 2nd Jun 2022 4:16pm
Mo Murphy
That not a bargain ! 🤔😯
You'll need a relay, some wire, a switch connector and some terminals for the LR switch, a fuse and holder and a couple of econoseal connectors to make a tidy connection at the lamp.
Google spotlamp wiring diagrams, the net is awash with them.
I'd be surprised if you spent more than £20 to do the job.
HTH
50 Shades of Pennine Grey
Post #954434 2nd Jun 2022 4:50pm
Stacey007
Thanks all...
I'm not paying £150...
In the same respect I'm colour blind so understanding wiring diagrams are a pain.. May enlist my 11 year Old son to help.
Thanks all.
Post #954562 4th Jun 2022 7:00pm
Stacey007
Just a thought....
Can I use an amazon generic kit... and use the plug that goes in the back of my switch?
So a kit like this
Then cut the switch off and use this into the back of the oem switch?
I still need to be able to do this but for £20 looks like it would do the same job?
Post #954565 4th Jun 2022 8:29pm
Mo Murphy
Yes you could 👍
Post #954586 5th Jun 2022 8:37am
