Home > In Car Electronics > Alpine 133BT
oldpostbob1
Alpine 133BT
Hi,
I have been offered an Alpine 133BT from a 2016 Defender.
I have a 2012 Defender with the standard radio / cd player.
I have removed this but the "sleeve" for the Alpine does not seem to fit into the slot.
Is there an existing sleeve to remove or do I have to butcher the existing (which I don't want to do)
to make the new sleeve fit.
Can't seem to find anything from anyone else having a problem so am I missing something.
Any help greatly appreciated.
Post #954135 31st May 2022 8:39am
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
If it's like mine, there are spring steel clips on the vertical inner edges of the opening for the radio. These can be carefully prised out, and then an Alpine sleeve will fit.
Will confess this took me a couple of goes to realise... ☺️ They're hard to see...
Post #954141 31st May 2022 9:11am
oldpostbob1
Thanks I'll have a closer look.
Post #954224 31st May 2022 6:55pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
If you're still stuck, some pictures would help me (and probably others) get our heads around the question.
I expect there's an original sleeve (or cage) to remove. There was when I did mine.
Best of luck
Thanks
Jon
Post #954225 31st May 2022 7:08pm
oldpostbob1
Jon,
Thanks for the reply - I will have a closer look and hopefully there will be a cage / sleeve as you say.
I'll let you know how I get on.
Thanks again.
BOB
Post #954226 31st May 2022 7:11pm
Gasket
There's some pieces to pry out that may still be there and some finishing with a file according to the LR 133BT installation manual: https://www.defender2.net/gallery/albums/u...DE0060.pdf
I know when I fitted mine, the alpine cage was incredibly tight in the hole and had to be eased very slightly with a file.
Post #954251 31st May 2022 11:13pm
skidrov
Yep, the items on p.1 box 4 of the guide that Gasket posted are what I encountered!
Post #954252 31st May 2022 11:22pm
