![]() | Home > Maintenance & Modifications > Snap-On Impact Driver PIT120 Operation?? |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 ![]() ![]() ![]() |
Evening all
I've got a few seized screws and bolts around my Defender 90. Several folk have commented about using an impact driver so when one came my way in the week I got it. Sadly it has no instructions and I can't find any. On the body it has a left and right arrow with matching On and OFF. So you can rotate the 3/8" stub left and right which I presume is On and Off ... BUT, I was expecting some sort of Clockwise or Anti-clockwise setting to extract or tighten a screw or bolt. Can ANYONE clear up this tool's operation please .. ![]() Click image to enlarge ![]() Click image to enlarge Many thanks John PS: Viewed several Youtube channels and still not clear 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3707 ![]() ![]() ![]() |
Could you not just practice on a nut and bolt in a vice and find out? I’m pretty sure it’s “normal” as I’m off is to remove the nut/bolt. Just put it on, take up any slack and hit it with the mallet.
Should have mentioned that I'd tried that with no obvious effect ... what I think "Should be" straight forward is not. 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5868 ![]() ![]() |
Thanks Andy ... appreciate your time to find this article, the part I guess I was missing was to "Turn it in the direct you require"
![]() ... and on a lighter note, love the "Step 5" ... NO GLOVES in sight ![]() ![]() Have a good weekend John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
Are you going to use this impact driver on body fasteners?
Generally M6 body fasteners are very easy to shear off if nut is seized solid. M8 are a bit harder, but still can shear off. So no hammering on body. Of course as long as the bolt head or nut are not rounded. Larger bolts used for suspension components.. I guess 3/8" drive is a bit too small? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
The on/off thing seems to be a stupid Snap On thing. It is the same on a couple of my Snap On ratchet handles.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Hi Steve, maybe me but still not totally clear. I'm working on Off = Anti-clockwise (Undo) and On = Clockwise (Tighten). But really not clear, I have a Norbar 1/2" and that's crystal clear. John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
