![]() | Home > Technical > Defender TD5 rattle at 30mph'ish in 4th and 40mph in 5th.... |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5794 ![]() ![]() |
Check your exhaust manifold heat shield isn’t broken.
kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 66 ![]() ![]() ![]() |
Are you me? I literally wrote that for the garage when I took mine in for service a couple of months ago
![]() Turns out for my case, the nut mounting the gear stick to the seletor mechanism on the gearbox side is loose and just needs tightening. |
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 59 ![]() ![]() |
Good advice for the OP.
Also a good opportunity to adjust the gear lever bias springs to take up any play. This can make a huge difference to buzzes & rattles, & improves the gear selection. Cheers, Lionel |
