Home > Td5 > Alpine Window Glass Thickness
Paddington
Dear all,
I have a 2003 defender station wagon and need to replace the alpine window seals and filler strip.
With reference to the parts manual i have the option of having 5mm or 4mm glass - as i don't understand the reference system used to denote change points in the manual - i do not know what i have.
as it's a 2003 is suspect it is 4mm.
Can anyone confirm this or help with the change points please?
Kind Regards
Neil
Post #952597 15th May 2022 1:55pm
gilarion
Make sure you have a a seal filler strip tool as without one inserting the filler strip is almost impossible. And use lots of fairy liguid or silmilar as a lubricant.
Filler strip tool
https://www.ebay.co.uk/itm/195004671115?ha...XQMXRQ8A6N For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #952602 15th May 2022 2:18pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
If you are getting new seals and glass, I would say get the 5mm. It quieter Rolling with laughter and stronger Thumbs Up As above … get thee the proper tools Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #952636 15th May 2022 8:07pm
Paddington
Thanks for the tips. i'm having the windows tinted and the glazier is going to replace all the seals at the same time - so i'm not doing it and he's got quite a portfolio of defenders he's worked on. There are certain things i'm happy to try but anything with windows i'm happy to pay.
Post #952640 15th May 2022 8:33pm
lightning
Make sure the join in the seal is along the top edge and not the bottom, and make sure they use genuine LR seals.
Post #952658 16th May 2022 7:38am
Martin
Site Admin
5mm glass was fitted upto and including VIN numbers ending with EA344187
4mm glass was fitted from EA344188
The "E" is the model year. Slightly confusingly with 90/110/Defenders, the model year letters "A" to "G" were used twice, for 1984 through to 1990 (roughly corresponding to UK registration prefix letters) and again for 2010-2016 model years.
Anyway, in this case, the change point is in the 1980s range not 2010s range [as it's given in the pre-Puma parts catalogue].
So a 2003 Defender sits after EA344188 and was factory fitted with 4mm glass.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #952680 16th May 2022 10:58am
Paddington
thank you for the enlightenment Martin.
Very much appreciated - and notes taken to avoid repeating the question.
Kind Regards
Neil
Post #952683 16th May 2022 11:33am
