Home > General & Technical (L663) > 2021 Defender 110 L663 trailer electrics problem
TDAA
United Kingdom 2000 Defender 110 Other SW Auto Baltic Blue
I have a LR fitted detachable tow bar (UK) and all the trailer lighting has stopped working. It has a European 13-pin electric socket and I have been successfully using a 13-7pin adaptor on 3 different small trailers for a year and now none of the trailer lights work and the trailer symbol does not appear on the dash or the show towing as an option in cameras. I can measure 12v+ voltage on the permanent live pin and its earth but no voltage to be found on any other pins. I have checked and tested the only fuse related to the Towbar and I can’t see a way of fault finding an rectifying the issue. I have successfully tested all the trailers.
Today I hooked up a brand-new caravan with 13-pin electrics, the caravan's powered stabilizer activated - but no brake/turn/other lights work.
Any help or advice gratefully received.
Post #951550 4th May 2022 12:05pm
mrtayg
Turkey
Is there any option in the menu related to towing?
Post #951885 7th May 2022 6:32pm
mse
If you don’t have the menu option, sounds like the cars forgotten the towing option or the module has failed.
If a hard reset doesn’t fix it, then a dealer trip.
If it’s mission critical call lr assist Mike
Post #951901 7th May 2022 8:45pm
mrtayg
Turkey
Thanks for the reply. I will contact the dealer for the 4th time today. I hope they can understand.
Post #952014 9th May 2022 5:25am
TDAA
All fixed by dealer, you were correct - Apparently the tow module/controller had dropped out of the car’s software/settings and had to be reinstalled. At least it was covered by the warranty but who knows if it will mysteriously disappear again? Fingers crossed.
Post #952201 10th May 2022 6:24pm
mse
Glad it’s fixed Mike
Post #952214 10th May 2022 7:43pm
