Home > Puma (Tdci) > 2.2 clutch bleed nipple location? |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
I’ve just done this myself, on first inspection I thought ‘oh no, another nightmare job working on an invisible component buried under pipes and round a corner..’
.. it’s actually OK, best way I can describe it- lay down on the passenger side, just behind the mudflap with your legs pointing towards the drivers side. Shuffle under so you can look up between the tub and the gearbox. You can see the hard pipe coming up (which is from the master in the engine bay) which goes to part 1 shown in the diagram. There is a rubber cap on the nipple that pulls off and you should be able to open the bleed screw by hand, it turns between 1/4 and 1/2 a turn. Click image to enlarge I used standard dot4 fluid. 2014 Keswick Utility 2.2 |
29th Apr 2022 6:16pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
If you can’t turn it by hand you can use a 13mm stubby spanner on the two flats.
(Might help a little). $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
29th Apr 2022 7:57pm |
