Home > Puma (Tdci) > 2.2 clutch bleed nipple location?
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
The clutch fluid on my 2.2 needs changing.
I've had a quick look but I'm not sure where the slave bleed nipple is.
Also, what type of fluid should be used?
Post #950772 27th Apr 2022 7:48pm
UtilityTruck
I’ve just done this myself, on first inspection I thought ‘oh no, another nightmare job working on an invisible component buried under pipes and round a corner..’
.. it’s actually OK, best way I can describe it- lay down on the passenger side, just behind the mudflap with your legs pointing towards the drivers side. Shuffle under so you can look up between the tub and the gearbox.
You can see the hard pipe coming up (which is from the master in the engine bay) which goes to part 1 shown in the diagram.
There is a rubber cap on the nipple that pulls off and you should be able to open the bleed screw by hand, it turns between 1/4 and 1/2 a turn.
I used standard dot4 fluid. 2014 Keswick Utility 2.2
Post #951033 29th Apr 2022 7:16pm
If you can’t turn it by hand you can use a 13mm stubby spanner on the two flats.
(Might help a little). WeWillWin🇬🇧🇺🇸
Post #951051 29th Apr 2022 8:57pm
